Thread started 29 May 2004 (Saturday) 11:25
A question of color
aam1234
Joined May 2004
May 29, 2004 11:25 |  #1
Hello all,
Here and other places in the web I see photos with brilliant and vivid colors, mine look a bit dull and watered down. So the question is how one can make photos with such full-of-life colors. I cranked up the settings in the 300D, I believe it’s +1 sharpness, +2 saturation without much difference. All are jpegs and rarely do any post processing (with ACDsee Fotoconvace). Unfortunately I don’t have any photos in the net so I can’t shaw an example.
Any suggestion will be highly appreciated.
karusel
Joined Nov 2003
May 29, 2004 12:03 |  #2
I will assume nothing is wrong with your camera - if you want more vivid colors, you will have to start doing post processing. Fiddle with contrast, saturation and/or some filters and knock it up to your liking.
5D and holy trinity of primes. Now the 90mm TS-E TS-E fly bit me. I hate these forums.
Jim_T
Joined Nov 2003
May 29, 2004 12:21 |  #3
Yes.. I agree.. The built in camera processing doesn't hold a candle to a decent phot editing package where you can adjust your colours from very bright to downright unnatural.. I keep all my camera setting neutral and use post processing to adjust to my liking...
WestFalcon
Joined Nov 2003
May 29, 2004 12:28 |  #4
Get photoshop le or elements and do more post processing...a necessary evil...but worth the time.
msvadi
Joined Jul 2003
May 29, 2004 12:39 |  #5
First of all, what kind of pictures do you usually take? In the reality, colors are usually mixed-grey. It is hard to find pure, saturated colors in the real life. And Canon equipment is famous for its ability to reproduce colors accurately. Brain can trick the eyes, and we can "see" what is actually not there. The camera captures the reality. If one wants to get beautiful pictures he has to find the right light, the right subject and expose correctly.
Second, probably, the majority of really beautiful pictures that you see on the web have been post-processed. Photoshop can help to "fix" the reality a little bit. Still, the light and the exposure are much more important.
Having said all that, I actually think that the 300D at its default setting usually produces more saturated pictures. I shoot RAW, and I can see it by comparing embedded jpegs with files coming out from RAW conversion.
drisley
"What a Tool I am"
Joined Nov 2002
May 29, 2004 14:04 |  #6
I find that adding too much saturation at once in Photoshop can produce colour artifacts.
What I do is make an action where you increase saturation by 5%.
Then, just play the action over and over until you get the saturation you like.
For some reason adding to the saturation in increments like this allows you to add much more saturation before artifacts appear.
You might also want to search this forum and google for "velvia" plugins.
They might be exactly what you need.
This is an extreme example.
Unprocessed Raw:
Velvia w/ Boosted Saturation:
Some prefer the less saturated since it shows more detail, some prefer the more saturated even though some detail is lost in the blown out colours. It's a matter of preference.
EOS R6 Mark II - Sigma 50/1.4 Art - Sigma 14-24/2.8 Art - Canon EF 70-200/2.8L Mark III - Godox Xpro-C - Godox TT685C x2
topeju
Joined Apr 2003
May 29, 2004 14:18 |  #7
I'm sure you knew this already, but I'll say it just for the sake of completeness. I often have trouble following my own advice. :-)
It also helps to shoot in better light. In direct midday sunshine, colours will usually be bland and uninteresting, whereas shooting at sunrise or sunset, or under overcast skies, will give more saturated colors naturally, without post-processing (which still won't hurt though...).
Tomi Junnila
Kaarina, Finland
whowie
Joined May 2004
May 29, 2004 14:47 |  #8
If you have Photoshop, try this:
1. Create a duplicate of your master (background) layer
2. Saturate the heck out of this new layer; Image-->Adjustments-->Hue/Sat; something over +65; experiment, but the more the better
3. Change the blend mode on the new layer to Color
4. Use the Opacity slider to control the color intensity
When you have something you like save copies of the file as PSD (you're working original) and JPG (completed original).
http://www.flickr.com/​wesleyhowie (external link)
Canon EOS 70 D, Canon EOS 30D,150-600mm F/5-6.3 Di VC USD SP, assorted lenses, flashes, filters, bags, tripods, some film gear, etc. etc.
drisley
"What a Tool I am"
Joined Nov 2002
May 29, 2004 21:37 |  #9
Great tip Whowie!
That method gives great colour without losing detail in highly saturated areas.
Thanks alot :D
2,218 views & 0 likes for this thread, 8 members have posted to it.
A question of color
2570 guests, 94 members online
