Thread started 29 May 2004 (Saturday) 14:25
E-TTL, active focus point, and compensation
Tom ­ W
Canon Fanosapien
Joined Feb 2003
May 29, 2004 14:25 |  #1
I did a little experimenting today with the flash, and thought I'd share the results. While many here are already familiar with the "quirks" of E-TTL, there are quite a few here that might benefit from this.
Anyway, here it is:
Mr. Tan Hat and Miss White Door have decided to get married, and have invited Tom W as their photographer. So Tom, always eager to the task gathers up his 10D, appropriate lenses, 550EX flash, a few sets of batteries, and assorted other equipment and heads off to take some wedding photos.
In the first photo, the active focus point is centered right over Mr. Tan Hat's tan hat. This provides a satisfactory, balanced exposure with some detail showing in both Mr. Tan Hat's dark jacket and Miss White Door's white dress.
http://images.fotopic.​net/?id=4790681
In the second shot, the active focus point lands right over the dark jacket that Mr. Tan Hat is wearing. Due to the way E-TTL biases the flash exposure to the active focus point, this results in good exposure of the dark jacket, but overexopsure of the picture in general. Note the blown-out detail in Miss White Door's garb.
http://images.fotopic.​net/?id=4790679
After checking his histogram, Tom the photographer quickly adjusts his flash exposure compensation. Since he usually shoots at +1/3 FEC, he subtracted 1 whole stop from that and took the same shot with a net FEC of -2/3 stops. This brought an overall satisfactory exposure again, with detail in both dark and light areas.
http://images.fotopic.​net/?id=4790677
Minutes later, Tom the photographer takes another picture, this time placing his active focus point right over Miss White Door's bright white dress. The camera exposes the dress a little under, but leaves the rest of the composition very underexposed.
http://images.fotopic.​net/?id=4790678
Again, after checking the histogram, Tom the Photographer readjusts the FEC from the +1/3 setting that he usually uses to +1 1/3 stops and re-takes the picture. This time, the overall exposure is balanced with detail showing in both dark and light areas.
http://images.fotopic.​net/?id=4790680
Because Tom the photographer effectively used his histogram and his flash exposure compensation when dealing with very light or very dark subjects, he was able to take several hundred wonderful pictures of the new Mr. and Mrs. Tan Hat's wedding. They loved the pictures, paid him a handsome sum, and everyone lived happily ever after.
Tom
5D IV, M5, RP, & various lenses
Cadwell
Joined Jan 2004
May 29, 2004 14:45 |  #2
As long as you got paid, that's alright ;) :lol:
Interesting example :)
Glenn
My Pictures: Motorsport (external link)/Canoe Polo (external link)/Other Stuff (external link)
Tom ­ W
Canon Fanosapien
Joined Feb 2003
May 29, 2004 14:48 |  #3
Why Mr Tan Hat gave me the coat off his back. ;)
Tom
robertwgross
Joined Nov 2002
May 29, 2004 14:52 |  #4
Good example. You better write a "how-to" book.
---Bob Gross---
Mike ­ H
Joined Jan 2004
May 29, 2004 15:57 |  #5
Tom, it looks like from those results that unless we are dumb enough to put the active focus point over a pure white or a pure black, we'll probably land on our feet when using E-TTL2 (especially if shooting RAW).
I wonder what would have happened if you used bounce flash instead? Maybe the happy couple will need some honeymoon photos.
Thanks.
Mike H
Tom ­ W
Canon Fanosapien
Joined Feb 2003
May 29, 2004 16:16 |  #6
Well, if II is as good as promised, you should be able to compose the picture as you wish without worrying about extreme dark or light subject material. And sometimes, in order to get the composition you want, the active focus point unfortunately does fall over the bride's dress or veil, or the groom's navy tux (or the black Mercedes in the garage or whatever).
I shot these RAW, but didn't do anything to them in the conversion - they're pretty much straight out of the camera.
Thanks.
Mike H
Bounce flash would have brought similar results (without the shadow of Mr. Tan Hat's hat, of course). E-TTL meters on the reflected light of the pre-flash, and will automatically adjust output to compensate for bounce, or diffusers and such, so that the same amount of light will hit the target.
I've shot a few with bounce on this flash, but this was adequate to illustrate the effects of dark and light subjects and the necessary FEC that helps overcome these effects.
If I get a chance after dinner this evening, I may fiddle around a little more with bounce. The 550 is new for me, but it does resemble my 380EX enough that it has been pretty easy for me to adjust to.
Tom
Mike ­ H
Joined Jan 2004
May 29, 2004 18:37 |  #7
Thanks for the response.
I'm not so sure about bounce giving you the same results, since this new system is working distance into the equation, something that is complicated by the use of bounce flash. I will have to convince myself that you're right with some tests.
You would likely get different results if custom function 14 were set to average exposure over the entire AF elipse (page 151 of the manual), rather than evaluative metering. Several users on another board report better results when setting the flash metering to the averaging pattern. In your sample photos, my guess is that it would work better (since it would average the blacks and whites). It would be critical for wedding shooters to know which pattern works better.
I'm planning to do some tests when my neighbors come back into town in a few days. They're such good sports. :D
Mike H
Tom ­ W
Canon Fanosapien
Joined Feb 2003
May 29, 2004 18:54 |  #8
Mike H
I apologize, Mike - I probably should have noted that I'm shooting with the 10D. All I have is "regular" E-TTL, not the newer version. Which is why bounce flash really won't change the exposure in my case.
Given that you have E-TTL II, I would think that your results will be more consistent, especially if you have an average exposure option for tough situations.
I am looking forward to seeing how the newer E-TTL II does in a similar situation, especially since I am of the mind that Canon will include it in the next consumer grade digital SLR, just as they've included it in the Elan 7N. Unless I suddenly change professions (and start making money with cameras), I'm not likely to splurge on the 1D Mk II any time soon, even if I crave it.
Tom
Mike ­ H
Joined Jan 2004
May 29, 2004 19:24 |  #9
Tom, no need to apologize. I didn't read your original post carefully enough; you did say that you were using the 10D.
If it makes you feel any better about not getting a Mark II, it's heavy, expensive, and much more complicated to use than the 10D. I'm going to need a lot more time to learn this camera than the 10D. That's one of the downsides of having a ton of features.
Mike H
Sendide
Joined Jan 2004
May 30, 2004 00:44 |  #10
thanks for this very instructive example tom. as you said, there are a lot of people who will take great advantage of this post (myself included). but that makes me need to learn more about how to correctly read pictures histogram since that was how you guessed that the picture was over or under exposed. is it about how homogenous the histogram is? moreover, how do you know that the shot is over or under exposed (I mean for more complicated picture composition).
please feel free to giave some documentation references for better understanding histograms
regards
Khalid
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
May 30, 2004 07:39 |  #11
Very helpfull post!
Thanks Tom!
CDS' HOT LINKS
Tom ­ W
Canon Fanosapien
Joined Feb 2003
May 30, 2004 07:49 |  #12
Edited with histograms
Khalid, sometimes, you don't even need to look at the histogram to see if a shot is going to be way over- or under-exposed. The overexposed highlights will flash on the LCD after the shot, and the underexposed will just look too dark. But the LCD isn't the best tool for looking at the actual image except for composition. Better to use it to view the histogram.
Anyway, I always keep my camera LCD set to show the histogram along with a small version of the image. Unfortunately, I don't know how to get the histogram image into a JPG so that I can post it here, or I could show you just what I was dealing with.
EDIT: With the help of PacAce, I was able to preserve and create copies of the histograms for each of the 5 shots so I will include them with the following text as needed. Pardon the nasty JPEG artifacts on these - they aren't to be viewed as artwork. :)
Anyway, I'll "borrow" this simple chart from the Luminous-Landscape web site:
IMAGE: http://www.luminous-landscape.com/images7/dark-light.jpg
As you can see, the chart is simply a graph showing the quantity of pixels that exist in the image at the various levels of "darkness" or "lightness". The extreme left of the chart is black, while the extreme right of the chart is white and everything in between is varied levels of brightness.
Now, using the chart against my photos above, I'll try to describe what the chart looks like for each image (since I can't post them).
http://images.fotopic.​net …;noresize=1&​;nostamp=1
The first image is fairly well exposed. The histogram shows a fairly even distribution of dark and light pixels. More importantly, there are no pixels bunched up at either end of the chart.
EDIT: I probably could have exposed about 1/3 stop higher without overexposing, but in my opinion, there's enough leeway in a RAW image (or a JPEG really) to tweak 1/3 stop without any serious consequences.
Image #2 exposed to show detail in the dark jacket, but overexposed the overall image. On the histogram, this shows up with a large "lump" bunched up against the right end of the chart. This is indicative of "blown out" highlights, and will result in loss of detail in the brighter parts of the image (in this case, the grain of the closet door is lost). Blown out highlights will also flash in the LCD image display. (EDIT: See above)
Image #3, I have corrected the overall exposure by reducing flash output by 1 stop (in my experience, one stop is roughly equal to 1/5 of the histogram's chart or the length from one vertical bar to the next). This took care of the "blown" highlights on the closed door, and still kept some detail in the jacket. Virtually all of the histogram information is within the boundaries of the chart, with none bunched up against either end. Plus, there are no large areas at either end of the chart with little or no information. All the camera's output data is visible on the chart. This is a good exposure. (EDIT: See above)
Image #4, I've taken a shot of "Miss Closet Door" without compensating for the darker parts of the image. This produced good detail of the woodgrain on the door, but underexposed "Mr. Tan Hat's" jacket. The histogram shows a good deal of information in the center of the chart (the closet door), but also a large lump of data near the left (dark) end and almost nothing towards the right end of the chart. This is underexposed. (EDIT: See above)
The last image, I used flash exposure compensation to increase the exposure level by 1 stop. This resulted in a better exposure, with more detail on the jacket while retaining the detail of the white door. The histogram for this shot showed a large amount of data towards the right end of the chart (the door), but not bunched up against the end which would indicate blown out highlights, and the data that was close to the left end is more spread out and moved away from the left edge of the chart. This darker "bunch" of data is the dark coat. By getting it away from the left edge, it gives the data some "space" to show greater detail. (EDIT: See above)
One last note - once data is bunched up at either the dark or the light end, there is no differentiation between levels of lightness or darkness. It cannot be darker than black nor lighter than pure white. So, any differences in brightness in those parts of the photograph are lost.
Anyway, since I "borrowed" their chart, here is the link to an article at Luminous-Landscape that gives some information of the use of the histogram:
http://www.luminous-landscape.com …standing-histograms.shtml (external link)
Tom
Sendide
Joined Jan 2004
May 30, 2004 11:11 |  #13
Top contributer , top explanation :wink:
thanks a lot TOM
slin100
Joined Sep 2003
May 30, 2004 15:14 |  #14
It would have been interesting to see the effect of CF 4-1, which remaps AF to the * button, on ETTL. On a 10D (and probably the 300D), ETTL is supposed to operate more like an averaging auto flash in this case.
Steven
7D, 10D, 17-40/4L, 50/1.8 Mk I, 85/1.8, Tamron 28-75/2.8, 28-135/3.5-5.6 IS, 80-200/2.8L, 550EX, Pocket Wizard
SDK^
Joined May 2004
May 30, 2004 16:12 |  #15
Just going back to Custom Function 14 – Auto Reduction of Fill Flash
Can someone please explain the difference this makes and the possible situations you might use either option
:: Sony A7 III | Sigma 12-24 | Sigma 24a | Sony 55, 85 and 135 F1.8 | Canon 100 Macro L IS ::
4,341 views & 0 likes for this thread, 14 members have posted to it.
2570 guests, 94 members online
