Thread started 17 Jun 2007 (Sunday) 22:44
Why is my picture overexposed?
Undiscovered
Jun 17, 2007 22:44 |  #1
Setup: Canon XT, 28-70mm, w/ tripod.
I was at a local nature trail and tried to slow the shutter speed to capture waterfalls in a cotton appearance. I've done it successfully once before using 0.3" (different waterfall however), but this time the picture looked over exposed regardless. Why couldn't I obtain a more cotton affect?
This is the picture, and below are the specs
http://www.flickr.com/​photos/8250417@N03/543​144590/ (external link)
Tv(Shutter Speed)
0.3Sec.
Av(Aperture Value)
F22
Metering Modes
Centerweighted average metering
Exposure Compensation
0
ISO Speed
100
Lens
28-70mm
Focal Length
28.0 mm
Image size
3456 x 2304
Image Quality
RAW
Flash
Off
White Balance
Cloudy
AF mode
One-Shot AF
Here is the second take with a faster shutter speed, but it's still not the cotton look I was looking for, but it looks better.
http://www.flickr.com/​photos/8250417@N03/543​266189/ (external link)
Tv(Shutter Speed)
1/25Sec.
Av(Aperture Value)
F22
Metering Modes
0
ISO Speed
100
Lens
28-70mm
Focal Length
28.0 mm
Image size
3456 x 2304
Image Quality
RAW
Flash
Off
White Balance
Cloudy
AF mode
One-Shot AF
davidcrebelxt
Jun 17, 2007 22:56 |  #2
One possibility was the scene may have been too bright for a slower-shutter speed. Once you've closed down the aperture all the way (higher f-stop) and lowered your ISO (100) as you did... the only other ways to get slower shutter speed in some scenes is by using a polarizer to drop by another f-stop or so... or you'd need to use Neutral density filters to block the overall amount of light entering your lens.
David C.
Equipment: Canon Dig. Rebel XT; 18-55mm EF-S; 28-105mm EF; 50mm 1.8 EF
Sigma ef-500 DG ST, Elements, Gimp, Lightroom
http://www.flickr.com/​photos/dcrebelxt (external link)
notsotechie
Jun 17, 2007 23:13 |  #3
As for the first photo the shutter speed is a bit too long.
aecond one it bit of an improvement should have gone a litttle more higher shutter speed.say about 1/100 to1/ 250 sec
first of all I think part of the problem is based on the white balance is in cloudy mode.
if you have DPP reload the picture and see if you can change the white balance mode.
say to landscape? and mabye do a few more tweaks.
give it a try
If you have DPP version 3 then it would be great. or what ever program you use for PP
other wise maybe invest in some good ND filter set.
wait for other to give there input.
:) Canon Rebel XTi and bag full of goodies.
Curtis ­ N
Master Flasher
Jun 17, 2007 23:13 |  #4
Sunshine is too bright for 0.3 seconds and f/22. 1/50 and f/22 would be about right for full sun. Your lens simply couldn't stop down enough to avoid overexposure with a shutter speed that long. If you used Tv mode, the aperture value in the viewfinder would have been blinking. It's important to keep an eye on that.
A polarizer would give you maybe a couple stops and allow perhaps 1/12. To get slower shutter speeds in sunshine you'll need a neutral density filter of more than 2 stops.
jt168
Jun 17, 2007 23:38 |  #5
Or trying early in the morning or late in the afternoon when it's not as bright...
My Blog - JAY TSAI photography (external link)
Canon 30D | Canon 40D | Canon 5D | 10-22 EF-S | 17-55 IS F/2.8 EF-S | 24-70L F/2.8 | 70-200L IS F/2.8 | 100 Macro | 85 F/1.8 | 50 F/1.4
Undiscovered
Jun 18, 2007 00:15 |  #6
Thanks guys.
snyper77
Jun 19, 2007 16:25 |  #7
I don't see what "mode" you were shooting in. If you were in M mode, then you simply didn't watch your meter and/or get your shutter/ap. settings correctly. Now, if you were in Av mode..... or Tv mode.... and you got an overexposed image, then possibly when the camera 'grabbed' the other half of the exposure (av or ap), then it could have been maxed out and blinking at you, telling you there was a problem......but was un-noticed.
1,919 views & 0 likes for this thread, 6 members have posted to it.
2742 guests, 143 members online
