Thread started 17 Jun 2007 (Sunday) 23:14
Photoshop gurus (or graphic artists)...I need help
David ­ John
Jun 17, 2007 23:14 |  #1
I really want to know how to do something like this for my daughter's senior photo...
Can anyone here provide an online tutorial (or know where I may find one) that explains these techniques??
Thanks,
Dave
_____________________________
"A true photograph need not be explained, nor can it be contained in words
" ~ Ansel Adams
Swift
Jun 18, 2007 09:55 |  #2
Pretty simple stuff. I can explain it in a quick little paragraph...
Here is a quick explanation of the bottom photo:
Simply find some grunge brushes, or a texture. Now copy that texture or draw over your background with it.
Then, select two colors in your background and foreground place (on the toolbar at the bottom) and on a new layer above the background layer go to Filter > Render > Clouds. Set the clouds layer to Color.
Now, make a new layer for each photo you want on the document. Paste the photos on each layer (each photo having a seperate layer). Then, grab your brush tool, click the Layer Mask button (this can also be found in Layers > Layer Mask > Reveal All). Now you have a square next to your layer with one of your photos.
At this point, position your photos (hold CTRL then click and drag the photo) to the place you want it to be on each layer.
Then, add a layer mask (same way as before) to each photo layer (not the background layer) and grab a brush, make the background color black (toolbars, the top box make it black, so now you're brushing black on a layer).
Now, click on the top layer with a photo on it, and then click on the white box next to that layer. Now with your black brush, brush outside the person so it takes out the background and now reveals the layers under the layer you're brushing on right now (should be the top most layer).
I hope I made sense, feel free to ask any questions. This method is called blending, however. Layer Masks is what you need. You might want to move the layer with the mode set to Color above all your other layers, so it colors your other layers. And then set the opacity down to about 80% or whatever looks good.
Here is a photo of how you should be set just to help you out:
IMAGE: http://img.photobucket.com/albums/v715/kninja0/Lasers/XT%20Camera/technique-2.jpg
IMAGE: http://img.photobucket.com/albums/v715/kninja0/Lasers/XT%20Camera/technique.jpg
The only thing I added was I copied the background layer over two photos so the photos can have the texture like the second photo in your original post some people have in that photo. So, I lowered opacity on that texture above my photo layers. Some of the people in the second photo in your original post do not have a texture, so I put those layers above the background copied texture layer.
Canon 550D | Canon 70-200mm f/4L USM | Canon 17-55mm f/2.8 IS USM | Canon Speedlight 430EX | Raynox DCR-250 Macro
dzstudios
Joined Feb 2006
Jun 18, 2007 20:44 as a reply to  @ Swift's post |  #3
For a more graphical explanation of layer masks - try googling 'photoshop tutorial layer mask'
Here's one I found: http://www.myjanee.com​/tuts/layermask/layerm​ask.htm (external link)
Also - quicker than finding grunge brushes and painting your own background - just google IMAGES for 'grunge texture'
Here's one I found:
The card with the headlines and banners on will require a photograph that's set on a white background, otherwise you'll have to cut out the image yourself...
The text has an effect on it, called DROP SHADOW... once again - google for a tutorial on photoshop drop shadows -- and you will find 1000s!
Being a designer, I would ofcourse, recommend that the easiest way is to pay a professional to do it for you.
Corporate photographers by necessity, music photographers by choice: www.d-z.co.uk (external link)
Come to Africa with us -- www.namibiandreams.blo​gspot.com (external link)
David ­ John
Jun 20, 2007 16:03 as a reply to  @ dzstudios's post |  #4
Thanks guys...you're AWESOME!!
" ~ Ansel Adams
cgratti
Lord_Malone, your still a newb...
Joined Feb 2004
Jun 20, 2007 23:18 |  #5
The first photo would be better suited for Adobe Illustrator, it works text much better than Photoshop.
Canon 30D
Canon 10D
Canon 28-105 f/3.5-4.5 II USM
Apple iMac G5
1,695 views & 0 likes for this thread, 4 members have posted to it.
2700 guests, 146 members online
