Adding fill-light seems to do the same as bumping exposure so I am wondering what the difference is and when it is appropriate to use either ?
tommykjensen Cream of the Crop More info | Jun 18, 2007 12:57 | #1 Adding fill-light seems to do the same as bumping exposure so I am wondering what the difference is and when it is appropriate to use either ? EDITING OF MY PHOTOS IS NOT ALLOWED
In2Photos Cream of the Crop 19,813 posts Likes: 6 Joined Dec 2005 Location: Near Charlotte, NC. More info | Jun 18, 2007 13:09 | #2 Fill light is supposed to increase just above the lower end (darks, shadows) of th ehistogram, while exposure increases the entire range of the histogram. When you use Fill light it seems like it affects the entire range because as you bump the lower range it moves into the upper range. But Exposure moves the entire range all at once. Mike, The Keeper of the Archive
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Jun 19, 2007 01:23 | #3 |
goatee "nice but dim" 5,239 posts Joined May 2005 Location: North of London, UK More info | Jun 19, 2007 07:12 | #4 It's worth noting that exposure shifts the whole histogram to the right, and is used to set white point. Blacks is used to set the black point, and fill light just lifts darker tones, whilst leaving black and white points. D7100, 50mm f/1.8, 18-140mm f/3.5-5.6, 70-300mm f/3.5-5.6 VR, SB800
Jun 21, 2007 06:19 | #5 Thanks all. EDITING OF MY PHOTOS IS NOT ALLOWED
goatee "nice but dim" 5,239 posts Joined May 2005 Location: North of London, UK More info | Jun 21, 2007 07:18 | #6 <shameless plug which will probably be deleted quite reasonably by a mod> D7100, 50mm f/1.8, 18-140mm f/3.5-5.6, 70-300mm f/3.5-5.6 VR, SB800
| Latest registered member was a spammer, and banned as such! 2707 guests, 147 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
