Thread started 19 Jun 2007 (Tuesday) 12:35
RAW processing options?
DDan
Jun 19, 2007 12:35 |  #1
I need to process/convert CRW and CR2. It appears that DPP can't handle CRW. I have been using Canon RAW Image Converter but I prefer to do adjustments to the CRW before conversion like I do in DPP with CR2. I did some research last night and BreezeBrowser appears to be a possibility. Anything else I should look at?
DansRacePhotos.com (external link)
Dangerous Dan
In2Photos
Jun 19, 2007 12:54 |  #2
DPP should handle CRW files as they are Canon files and DPP is Canon software. CRW files are older so any version that handles CR2 files should also work with CRW files. That is weird.
Otherwise there are a ton of possibilites, some free, some with minimal cost, some very expensive. My personal choice is Lightroom from Adobe.
Current Gear and Feedback
davidcrebelxt
Jun 19, 2007 12:57 |  #3
RawTherapee I've heard does a pretty good job, and is free.
If it doesn't read .crw files, just note that it also reads .dng, so you could use the free Adobe .dng converter, then use the .dng in Rawtherapee.
David C.
Equipment: Canon Dig. Rebel XT; 18-55mm EF-S; 28-105mm EF; 50mm 1.8 EF
Sigma ef-500 DG ST, Elements, Gimp, Lightroom
http://www.flickr.com/​photos/dcrebelxt (external link)
DDan
Jun 19, 2007 15:10 as a reply to  @ davidcrebelxt's post |  #4
Well BreezeBrowser is not working. It crashes on a regular basis while working on files. I'm looking at Elements 5 on the Adobe site but can't find exactly which RAW files are supported. I'm not really interested in most of the things that Elements does.
Dangerous Dan
davidcrebelxt
Jun 19, 2007 16:54 |  #5
DDan wrote in post #3405510 (external link)
Elements ACR is very limited, and if you're not going to be using the rest of Elements, its not worth it.
Try again with a newer version of DPP, I'm surprised its not reading your CRW's too. Or try Canon's Zoombrowser.
Did you try RawTherapee?
David C.
jnevin
Joined Apr 2004
Jun 19, 2007 18:39 as a reply to  @ davidcrebelxt's post |  #6
Try the free demo versionBibbleLite...mu​ch more versatile than DPP
DDan
Jun 20, 2007 00:40 |  #7
jnevin wrote in post #3406533 (external link)
Bibble doesn't support G1 CRW. ???
Dangerous Dan
DDan
Jun 20, 2007 00:44 |  #8
davidcrebelxt wrote in post #3406033 (external link)
My version is too new. Canon has dropped support of G1 CRW. Zoombrowser works but I don't have any control of the conversion.
BreezeBrowser is working OK for me now. We'll see how it goes.
Dangerous Dan
DDan
Jun 21, 2007 12:21 as a reply to  @ DDan's post |  #9
I didn't want to leave this thread as is because someone might find it later and get the wrong idea about BreezeBrowser. It works great and has solved several issues I had. The more I play with it the more I like it.
Dangerous Dan
Pugwash
Jun 21, 2007 16:59 as a reply to  @ DDan's post |  #10
I've used more than one version of DPP (currently on v3.0.1.5) on the CRW files that come out of my 300D. There appears to be no problem so can't understand why you can't get DPP to work on your CRW files. Have you tried Canon's Support and asked the question?
1,106 views & 0 likes for this thread, 5 members have posted to it.
2707 guests, 147 members online
