Thread started 19 Jun 2007 (Tuesday) 19:09
Changing the background?
TeriD
Jun 19, 2007 19:09 |  #1
I have seen some pics where they changed the background and left the subject in place. One pic I seen somewhere was they changed the color or a wall behind the subject but made it go from a light color to a darker color. Is there any instructions for this?
Damo77
Jun 19, 2007 19:19 |  #2
Are you using Photoshop?
Damien
Website (external link) | Facebook (external link)
TeriD
Jun 20, 2007 00:11 |  #3
Yes, CS2
ed.
Jun 20, 2007 00:47 |  #4
There are plenty of tutorials on this. Try googling?
You can use the quick mask mode to 'colour in' the subject.
When you exit QM mode it has a marque around the whole image minus the subject you coloured in.
Then you can copy and paste the selection on to another layer to adjust.
I'm sure there are other/better ways to do it.
http://www.edwardhor.c​om (external link)
http://www.flickr.com/​photos/edwardhor/ (external link)
http://www.modelmayhem​.com/EdwardHor (external link)
http://www.twitter.com​/edwardhor (external link)
justAL: PIxel peeping is what separates the men from the boys!
TeriD
Jun 20, 2007 01:03 |  #5
I did try googling it to find any tutorials but it comes up with mainly changing color in the pic itself.
ed.
Jun 20, 2007 01:11 |  #6
TeriD wrote in post #3408331 (external link)
Fair enough.
Hope my previous post gives you a guide on how to do it.
TeriD
Jun 20, 2007 01:47 |  #7
Thansk Ed, I'll give that a try.
Damo77
Jun 20, 2007 02:02 |  #8
I'm with Ed. I was going to recommend Quick Masking too.
It's not terribly "quick" while you're learning it, but before too long you'll find it indispensible.
Damien
howzitboy
Jun 20, 2007 04:31 |  #9
to change one color u use the replace color tool :
image>adjust>replace color its pretty easy to do.
to change the background totally, u need to use quick mask to select the subject or background (whichever is easier), then either copy the subject to a different bg or delete the old one and put in new one.
http://onehourwedding.​blogspot.com/ (external link)
freebird
Jun 20, 2007 09:54 as a reply to  @ howzitboy's post |  #10
If your just wanting to change a wall color......hue/sat layer works and adjust the hue for that color. Or use master color mode and change hue for alot more different colors then layer mask to keep all your other colors the same.
Chuck
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Jun 20, 2007 14:47 |  #11
Teri,
What you are asking involves two sets of skills, and I am not sure which you are trying to learn about.
First, there is altering the color. In the Photoshop Help Section, use the index and look up words like "Color" and "Hue" and study all sub-sections pertaining to "changing". Also, look up "Blending" and "Blend Modes" as that can come into play as well.
Second, there is altering part of the shot, but not all. In the Photoshop Help Section, use the index and look up words like "Selections", "Layers" and "Masks" and study all sub-sections pertaining to "tools" and "using".
Brush up on those two skills and you will have it.
Oh, notice that in both cases, the first step is to open the Photoshop Help Section. This is a little known and under-utilized technique that can assist with a multitude of Photoshop questions.
But now you have two places to start.
Rad
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
jackprks
Jul 04, 2007 09:50 |  #12
I followed the instructions above and created a new background Layer but cannot see it and don't know how to view it. I have gone through help but no help with this! What do I do now? If it is there, I can't find it. :oops: :confused:
JACK Photos http://www.flickr.com/​photos/parksplace (external link)
350d, Kit 18-55,, EF 50mm 1.4, Sigma 70-300 4/5.6 APO DG Macro, Sigma 17-70 2.8/4.5 DG Macro, Sigma 105mm 2.8 Macro, Opteka 7000 tripod, Monfroto Monopod & 785B Modo , Sigma 500 super, Delta flash breacket, Kenko turbes, cards and batteries.
Radtech1
Joined Jun 2003
Jul 04, 2007 11:12 |  #13
Here is a screen cap from the Layers Palate Elements 2.0
The information holds true for all iterations of PS and PSE.
Notice that I have an image with two layers. Can you see the difference? On the right hand layers palate, there is a little eyeball that is in a tiny box. Notice that the eyeball is not "turned on" on the left layers palate. The eye is turned on and off simply by putting the mouse pointer in that little box and clicking. When the eye is there, that layer is visible.
Also notice the word "Normal"
That drop down menu gives you the different "Blending Options". They are categorized by what they do - there are Darkening, Lightening, Contrast and a couple of Miscellaneous options.
Play around with them.
Rad
freebird
Jul 04, 2007 11:14 as a reply to  @ jackprks's post |  #14
are you working in the layers pallete? Is the eye icon on that layer so you can view it?
JaertX
Jul 04, 2007 11:26 |  #15
TeriD wrote in post #3406661 (external link)
didn't notice it mentioned on here, but a great way to drop the background is the extract filter. google russel brown...he has a tutorial on his website.
Jason - I use Canon and stuff
2,136 views & 0 likes for this thread, 11 members have posted to it.
2735 guests, 138 members online
