Thread started 20 Jun 2007 (Wednesday) 13:44
Aircraft pics. Question please.
Vulcan58
Jun 20, 2007 13:44 |  #1
Hi.
I like to take pics of everything & anything, & I love some of these 'Plane pics, but how do you get them all so perfectly exposed?
Which mode do you use to capture them so 'spot on'?
I've tried in the past but obviously the background is the brightest, and therefore aircraft/heli's have resulted in under exposure.
Learning all the time.
symbolphoto
Joined Nov 2005
Jun 20, 2007 14:04 |  #2
Do you have an example of one of your photos that may have not come out so well? If so i can probably point out some things. You can fix a lot of things in post processing..
Vulcan58
Jun 20, 2007 14:11 |  #3
mumbles wrote in post #3411028 (external link)
Not to hand i don't, mumbles. Maybe in a day or 3, I may be able to fish something off a DVD or something.
But out of interest, what settings do you use? Av, Manual? Tv?
Most of the time I 'cheat' and use the standard auto setting, but for movement, tend to use Tv, and for static objects - Av.
Also I don't tend to change ISO if possible - I just use 'my loaf' - Bright/sunny conditions then 100 - maybe 200. Low light, then perhaps 400.
Hope I don't sound too much like a no brainer :sad: ???
johndm
Joined Jul 2004
Jun 20, 2007 14:19 |  #4
Vulcan58 wrote in post #3410939 (external link)
Hi.
AV priority at f8...OR shutter priority at around 1/320th.
AI servo focus, centre point focus only.
Evalutive metering at plus 2/3 exposure compensation.
400D with 100-400L..check my link below to see how it works for me..:D
My Very Best Aircraft Pictures (external link)
symbolphoto
Joined Nov 2005
Jun 20, 2007 14:33 |  #5
Well it depends if you are shooting jet or props/helos. I'd go as fast as possible on jets, and around 125th to 150th on props.
I only shoot manual mode. But that's my personal preference. I can see the value in using Tv, but i just get used to my settings and set them, and usually it's close enough on most of my shots, although i do keep close eye on the meter to ensure it's center or close to.
http://brendanstewart.​net/oceana2006/airshow​18.jpg (external link)
http://brendanstewart.​net/oceana2006/airshow​19.jpg (external link)
http://brendanstewart.​net/oceana2006/airshow​63.jpg (external link)
http://brendanstewart.​net/oceana2006/airshow​43.jpg (external link)
All shot using the 100-400L. Mainly in M mode if i remember correctly.
Mumby
Jun 20, 2007 14:50 as a reply to  @ symbolphoto's post |  #6
Hi,
My personal preference is to shoot in Av mode for jets, and Tv for props. I normally over expose by around 2/3 of a stop if shooting against a bright/brightish sky.
I admire anyone who does it in manual, I tried it once and didn't get on. The problem for me was that shooting aircraft often involves long pans , almost 180 degrees at airshows for example. This means that the amount of light can really change a lot, so my fingers ended up dancing over the controls to keep the exposure right, rather than mashing the AF and shooting!
Paul
Cathus
Jun 20, 2007 15:54 |  #7
I use centre spot metering, TV mode 1/500 or faster for jets 1/125-1/250 for props.
If the sky is white or very bright I'll add 2/3 to 1 stop extra exposure compensation, not necessary with a rich blue sky or where the jet is white or light grey.
practice your panning technique too, and don't try zooming in too much to start with as getting the whole jet in the frame can be tricky at first but it comes better with practice. I tend to point my feet more towards where the jet will end up rather than where it starts, I then twist round to pick up the jet and 'unwind' as it passes so my feet and hips are more in a natural position when I take the shot.
Canon EOS 1D MkIV / 5D MkII
17-40 f4 L | 24-105 f4 L IS | 70-200 f2.8 L IS |
100-400 L IS | 600 f4 L IS | Canon MP-E 65 Macro | Tamron 90 SP Di Macro & Sigma 18-50, 10-20 & 50-500mm
blog.glnphotography.co​m (external link)
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jun 20, 2007 20:41 |  #8
“Film tricks” can help you out.
Need an exposure crutch?
Airshow guys - prop freeze?
Vulcan58
Jun 21, 2007 11:34 |  #9
PhotosGuy wrote in post #3412784 (external link)
Thanks all for the replies.
Will take note and see if I can get some soon.
symbolphoto
Joined Nov 2005
Jun 21, 2007 13:49 |  #10
Go near an airport and practice. No need to wait for another airshow... They are slower but in terms of getting used to lighting and panning, surely wouldn't hurt.
RCoulter
Jun 21, 2007 14:52 |  #11
mumbles wrote in post #3416250 (external link)
Exactly what I do/did:)
Airliners.net (external link) / JetPhotos.net (external link)
Canon EOS 1D MKII N/40D/20D/7D | 100-400L |
Canon 24-70 F2.8 L| 28-135 IS | Sigma 70-200 F2.8 APO DG |Sigma 50-500 APO RF
1,725 views & 0 likes for this thread, 7 members have posted to it.
916 guests, 109 members online
