Thread started 31 May 2004 (Monday) 14:53
Why can't I see EXIF info in XP?
Adam ­ Hicks
Joined Apr 2004
May 31, 2004 14:53 |  #1
I'm a computer nerd, so it pains me to ask this here, but I know I could always choose the Advanced Properties of the images I took with my S50 and see full image information. With images taken from my DRebel, I no longer have any of this information available.
Am I missing a setting on the camera or? I'm not shooting in RAW, but in highest JPEG mode.
Any help is appreciated!
Adam
300D / 28-75 F2.8 / 100mm f2.8 Macro / 18-55 kit / 420EX / Battery Grip / SanDisk Extreme 512 cards / B+W MRC filters / SD110 Elph P&S
mtndew
Joined Apr 2004
May 31, 2004 16:50 |  #2
what software are you using? Im still using zoombrowser that came with both G2 and Canon 10D also using Photoshop CS. and i haven't been run into any problems with EXIF
"If I could tell the story in words, I wouldn't need to lug a camera around" Lewis Hine
Jim
Elan 7n, G2, 10d and 30d Canon 28-135mm IS, 50mm 1.8 Tamron 28-75mm, 18-270mm Sigma 80-400mm, 70-200mm f/2.8, 150mm Macro, Sigma 12-24mm aka Popeye
Jim_T
Joined Nov 2003
May 31, 2004 16:51 |  #3
I can see my 10D info on XP.. Try this::
- Right click on the photo..
- Choose properties,
- Click on the summary tab..
- In the summary tab, click on the 'Advanced >>' button (It's on the bottom right part of the window.. under comments)..
You should see most of the EXIF info.... A few things are non standard and won't show up, but at least 90% of it is there.. If not, you've probably got something screwed up with Windows..
Penguin_101_1
Joined Feb 2004
May 31, 2004 17:25 |  #4
I think that after you change the file form the way it was when it was downloaded then you lose all EXIF info.
Adam ­ Hicks
Joined Apr 2004
May 31, 2004 19:11 |  #5
This always worked in Windows XP, built in feature not requiring any additional software. As described above, you check the properties of the image and turn on Advanced, showing you all of the EXIF information. Mine no longer does it with the DRebel. It doesn't give you the tab if you try to do it from the CF card itself, and it doesn't work on straight copies from the card.
Can someone with XP Home or Pro try this and see if it works for them? Someone with a DRebel?
Thanks!
Adam
Penguin_101_1
Joined Feb 2004
May 31, 2004 19:15 |  #6
What kind of file is it? JPEG?
JKSinMB
Joined Mar 2003
May 31, 2004 19:25 |  #7
Just checked and sure enough the exif info is there for JPEGs but not there for RAW files. I use a DRebel and XP Home.
defordphoto
MKIII Aficionado
Joined Oct 2002
May 31, 2004 19:28 |  #8
Adam: You are straight copying the files over and not using software of any kind to copy from CF to computer?
defordphoto | Celebrating the art of photography®
SD500, 10D, 20D, 30D, 5D, 1DMKII, 1DMKIII
www.ussbaracing.com (external link) | www.rfmsports.com (external link) | www.nwfjcc.com (external link)
An austere and pleasant poetry of the real. Ansel Adams
dn7elson
Joined Apr 2002
May 31, 2004 19:33 |  #9
I have a DRebel and direct copy my files, both RAW and RAW from the CF and do not lose the EXIF data. If you are dragging the files, make sure that you take the THM files with the CWR files when you copy.
JKSinMB
Joined Mar 2003
May 31, 2004 19:42 |  #10
Dale,
My RAW files retain the EXIF data and it can be viewed in photo editing/viewing software, but it doesn't show up when right clicking in Windows XP. This isn't an issue to me, I didn't even know you could see the EXIF data using Windows XP. I was just responding to Adam's request.
[/QUOTE]
Adam ­ Hicks
Joined Apr 2004
May 31, 2004 20:24 |  #11
Weird... yeah I'm just dragging the JPG and dropping it onto my desktop, and no dice on the EXIF info. I was wondering if this could be toggled in the camera, which is why I posted. Otherwise I can't figure out why the S50 would show it but the DRebel would not.
Hmmmmmm
Adam ­ Hicks
Joined Apr 2004
May 31, 2004 20:26 |  #12
Ok another quick test.. can someone please post a link to a .JPG file that you have with the EXIF info showing up on your machine? That way when I save it to my machine, I can determine whether it's the image file from my camera or my PC that is the problem here.
Thanks!!!
Adam
Chazs
Joined Aug 2002
May 31, 2004 22:15 |  #13
I don't know if this is helpfull or not, but when I right click a RAW picture in file explorer (XP) I don't see the EXIF in advanced properties. But upon extracting the the JPG and right clicking on the JPG I do get most of the EXIF data on the advanced properties.
I agree, it's a little odd that the RAW doesn't show the EXIF, but also, I usually on ly look at the EXIF in Zoombrowser or Photoshop CS.
CHUCK
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Jun 01, 2004 01:38 |  #14
Adam,
here ya go.
http://joebloggs.serve​beer.com …mages/images/IM​G_0155.JPG (external link)
p.s. thanks guys for the 16-35 advice. Awesome lens!
TF posting: here :-)
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Jun 01, 2004 01:39 |  #15
Bother. URL failure. Sorry!
try http://joebloggs.serve​beer.com …mages/images/IM​G_0155.JPG (external link)
(found the "edit" button - yay!)
another piece of useful (?) info, sometimes I get more EXIF info than others. copying a whole directory onto a Win XP mach at once gives different info in the same set of files...
8,127 views & 0 likes for this thread, 11 members have posted to it.
2570 guests, 94 members online
