Thread started 21 Jun 2007 (Thursday) 20:25
what graphics card are you guys running......
nodoubt
Jun 21, 2007 20:25 |  #1
just got a new amd dual core computer and have tried a few cards and not found a good one yet.....pics break up and stutter at full size while panning real quick??? is this normal or am i going to have to fork over 2 or 3 hundred bucks for a fast card ?? thanks....
40d....
50mm 1.8...tamron 28-75... ef 70-300 IS ....EF 10-22
manfrotto 3021BPRO
linhof PROFI III ball head
wimberly quick release, with a kirk plate
tinfish81
Jun 21, 2007 20:36 |  #2
How much RAM do you have? Should have AT LEAST 1 Gig....or preferably 2, 3, or even 4.
5D | 17-40L | 24-105L | 70-200L | 35L | 1.4X II | 580EX II
Space
Jun 21, 2007 20:38 |  #3
What kind of card do you have? And, how much memory is in the computer.
Common Sense...Isn't
30D ll 5D ll 24-70mm f/2.8L ll 70-200mm f/4L ll 200mm II f/2.8L ll EF 1.4 II
In2Photos
Jun 21, 2007 21:00 as a reply to  @ Space's post |  #4
I use the built in graphics card that came with my Mobo. I have 2GB RAM and don't have trouble like you are describing unless I am viewing a RAW file that I haven't let Lightroom build the preview yet, in which case is to be expected.
Current Gear and Feedback
davidcrebelxt
Jun 21, 2007 22:13 |  #5
I'm using a 3+ year old laptop with 1gb ram and of course onboard (shared) graphics... I don't see those problems either. How FAST are you trying to pan these images around anyway?
Actually a fast graphics card really doesn't affect image viewing that much... its more beneficial for 3d games and video.
Don't know what the problem might be honestly... Are you running Vista? Perhaps some of the enhanced OS graphics options are slowing your system down?
David C.
Equipment: Canon Dig. Rebel XT; 18-55mm EF-S; 28-105mm EF; 50mm 1.8 EF
Sigma ef-500 DG ST, Elements, Gimp, Lightroom
http://www.flickr.com/​photos/dcrebelxt (external link)
MJP
Jun 21, 2007 22:15 |  #6
I build a computer with two 7600gt SLI..with 4Gb
:grin:MarkIIN,5D w/ grip,PS SD10
70-200mm f/2.8IS Canon 1.4X II|sigma 12-24mm
| EF85mm f/1.8|Ef 24-105mmL | 100mm macro| RS-80N3 | MinoltaAutometer|I9900|CS2|LR|CS3| Angle Finder
Manf 190MF4 tripod, 680 mono, 322RC2 Joystick Head |
580EXII,580EX,430EX,ST​-E2,CP-E3
www.pbase.com/marlonjp (external link)
nodoubt
Jun 21, 2007 22:18 |  #7
amd, dual core 4000 processor...... 2 gig of ram....vista home basic that came with the computer....card is a pny 8500 gt with 512 meg of memory....dual 400 mghz ramdacs....450 mhz core clock....
40d....
manfrotto 3021BPRO
ed.
Jun 21, 2007 22:42 |  #8
I have onboard gfx with core2duo 2ghz, 1gb ram and don't have a stuttering in lightroom once it's finished loading.
What program are you using?
http://www.edwardhor.c​om (external link)
http://www.flickr.com/​photos/edwardhor/ (external link)
http://www.modelmayhem​.com/EdwardHor (external link)
http://www.twitter.com​/edwardhor (external link)
justAL: PIxel peeping is what separates the men from the boys!
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jun 21, 2007 22:49 |  #9
The graphics could only be a bottleneck if the work is being done in a 3D environment,.
Now if I;m not mistaken, Vistass implements a 3D environment in it's "Aero Glass" desktop.. if you turn this claptrap off, the problem will likely go away unless it's another Vistacruiser bug
CDS' HOT LINKS
Tony-S
Jun 21, 2007 22:56 |  #10
What CDS said. I'm running the Intel GMA 950. It's 64 mb of graphics space from my system RAM (plus 16 mb more for the processor management). It does photo manipulations very quickly.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
ed.
Jun 21, 2007 22:58 |  #11
You could try turning off the gadget bar as well.
SIMPLEPHOTOLT
Jun 22, 2007 09:41 |  #12
This might be obvious and you might have done it already, but try to change the setting for your monitor. Usually the monitor is set to be at 60Hz refresh rate. See if you can change this. It also has to do with your resolution setting also. Try to play around with these setting and the refresh rate see if there is any difference (and ofcourse everybody else's opinion's got something todo with it to.) Good luck.
LT
Canon 30D, 5D, Mk IV
Canon 100mm 2.8 Macro, Canon 18-55mm kit lens (for sale), Canon 50mm 1.8 II, Canon 75-300 4-5.6 II, Canon 24-105 f.4L, Canon 17-55mmm f/2.8IS, 85mm 1.8, 70-200L 2.8 IS Canon, Sigma 12-24mm EX, Kenko 25mm ET, Kenko 1.4x Pro 300DG
430 EX, Canon 580EX.
darktiger
Jun 22, 2007 10:01 |  #13
I am running the 8800GTS, I think the new CS3 Extended utilizes your videocard.
IMAGE: http://themoores.zenfolio.com/img/v1/p1032031579-4.jpg
My Flickr (external link)
My Zenfolio (external link)
xpsentity
Jun 22, 2007 11:20 as a reply to  @ darktiger's post |  #14
7950GX2, volt modded, clocked to 650/750(1500). Custom cooling.
Errrr....
Anyways, bottlenecks like that are likely the processor or lack of ram, not the video card. Unless it's really, really, really old and terrible.
Edit: After reading your system specs, I've no idea. I blame Vista. ;)
Black boxes, glass shards
http://entityzero.devi​antart.com (external link)
prime80
Jun 22, 2007 12:05 |  #15
Your video card and system in general should be well up to the task of Photoshop. And Vista basic doesn't include Aero if I remember correctly, so that shouldn't be the problem. Does this happen in other apps as well? Sounds like a potential driver problem to me, but there's not much to go on here.
John
R6, EF 100-400 L IS II, EF 24-70 L II, EF 85 f/1.8
Full Gear List
1,671 views & 0 likes for this thread, 13 members have posted to it.
2654 guests, 154 members online
