Thread started 01 Jun 2004 (Tuesday) 16:29
Parameter Setting or Adobe RGB For Raw Shooting
dsze
Joined May 2004
Jun 01, 2004 16:29 |  #1
If I'm shooting in RAW on my 300D, am I correct in thinking that the parameter settings don't do anything? Is it then better/more efficient to set the camera to Adobe RGB rather than a parameter setting?
-daniel
-daniel
"Life is not measured by the number of breaths we take, but by the moments that take our breath away."
-Gear List-
psk4363
Joined Jun 2003
Jun 02, 2004 04:42 |  #2
Hi Daniel,
You're absolutely correct re both of your questions - parameter settings have no effect of you shoot in RAW, and Adobe RGB is the better setting as it covers a wider colour space.
Cheers,
Barry
A little G9 :D
scottbergerphoto
Joined Jun 2003
Jun 02, 2004 07:09 |  #3
-daniel
The parameter setting affect the embedded JPEG and you can use them as the settings for the Raw conversion if you choose to do so. Some photographers use the embeded jpegs to quicky show clients their results, so the parameters are useful. Personally when I shoot Raw I use Adobe RGB for the larger color gamut.
Regards,
Scott
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography (external link)
dsze
Joined May 2004
Jun 02, 2004 09:52 |  #4
Thanks! Thats pretty much what I thought, but wanted someone more knowledgable to confirm. For my purposes, I think the larger gamut is more important than the JPG. Is there anyway to adjust the size of the JPG that is saved with the RAW file with the current Canon 1.1.1 firmware?
-daniel
-daniel
-Gear List-
slin100
Joined Sep 2003
Jun 02, 2004 10:17 |  #5
Yes. The size of the JPG can be set using CFn 8.
Steven
7D, 10D, 17-40/4L, 50/1.8 Mk I, 85/1.8, Tamron 28-75/2.8, 28-135/3.5-5.6 IS, 80-200/2.8L, 550EX, Pocket Wizard
yb98
Joined Feb 2003
Jun 02, 2004 10:26 |  #6
No, not with the canon firmware. But with the hack firmware yes.
Best DPP Threads
DPP++ Video Channel (external link)
New Version DPP++ 11.3 released (external link)
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jun 02, 2004 11:05 |  #7
The same thing that applies to the parameter settings.. also applies to Adobe RGB...
ie; It does not effect the raw image....
All selecting Adobe RGB does is tell the conversion program to use Adbobe RGB by default.. but just like parameter settings.. you don't need to have the camera in Adobe RGB to then convert the RAW file to a file with an Adobe RGB color space... :)
CDS' HOT LINKS
slin100
Joined Sep 2003
Jun 02, 2004 11:22 |  #8
Sorry. I didn't notice the OP had a 300D. What I said is definitely true with the 10D.
My memory is faulty but I also seem to recall that 300D RAW files embed two JPGs: a thumbnail-size and a larger one. I'll see if I can find the article that mentions this.
Steven
tommykjensen
Gallery: 6 photos
Joined Mar 2004
Jun 02, 2004 11:30 |  #9
Can someone expand on this?
I just took a RAW shot and converted it first with the sRBG..... profile saved it, then I converted the same RAW shot and converted it with the Adobe profile and saved it.
When I compare the 2 shots I don't see any difference?
EDITING OF MY PHOTOS IS NOT ALLOWED
yb98
Joined Feb 2003
Jun 02, 2004 12:32 |  #10
It depends on which software you use to view the pics. Not All viewers take into account the profile.
If you open your pics with photoshop you will probably see a difference.
Yacine.
Best DPP Threads
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jun 02, 2004 12:57 |  #11
...indeed.. what software are you using?
also... if you were to view th two images in there proper working spaces .. there is no guarantee that you will be able to see any difference..
Adobe RGB allows for a larger color gamut.. ie more colors are possibe in the image.. but this does not mean that the image you take will have more color.. nor that the image you take will reveal the additional color space...
CDS' HOT LINKS
tommykjensen
Gallery: 6 photos
Joined Mar 2004
Jun 02, 2004 13:19 |  #12
I just viewed the test images in PS CS and see no difference.
Does anybody have an example that show the difference?
dsze
Joined May 2004
Jun 02, 2004 13:20 |  #13
If I am correct, I think what happens when you have the parameters set is when you convert from RAW to JPG in PSCS, PS recognizes the new JPG as an sRGB file. When I have the camera set to Adobe RGB, and then convert to JPG, PS automatically recognizes the new JPG as an RGB, not sRGB.
So, if I have parameters set on my 300D and convert the RAW to JPG in PS, I am essentially asking PS to work with a smaller gamut (sRGB) and if I have camera set to Adobe RBG, then PS is working with the larger gamut, which may or may not even be noticable in every shot, but it can't hurt to have the larger gamut available......right?
-daniel
-daniel
-Gear List-
tommykjensen
Gallery: 6 photos
Joined Mar 2004
Jun 02, 2004 13:38 |  #14
I just compared the histograms and they are different.
The image in adobe colorspace
IMAGE: http://www.klein-jensen.dk/external/adobe.jpg
The histogram
IMAGE: http://www.klein-jensen.dk/external/adobe_histogram.jpg
The image in srgb colorspace
IMAGE: http://www.klein-jensen.dk/external/srgb.jpg
And the histogram
IMAGE: http://www.klein-jensen.dk/external/srgb_histogram.jpg
Anybody see the difference in the actual image?
Roger_Cavanagh
Joined Sep 2001
Jun 02, 2004 14:49 |  #15
The whole point of colour management is to get consistent colours across systems. The two pictures don't look quite the same in my browser (IE) because PCs "default" to using the sRGB space (more or less). Images in larger colour spaces, such as, Adobe RGB will tend to look flat and unsaturated.
Loading these images into Photoshop, they look very similar, which is what you expect and want. Depending on the colours in the original subject, sRGB may clip some colours that Adobe RGB does not. However, the colours are different as you can see from these gamut plots of the image data:
sRGB
Adobe RGB
The outline in the plots is the sRGB profile.
Regards,
Roger Cavanagh
www.rogercavanagh.com (external link)
4,203 views & 0 likes for this thread, 8 members have posted to it.
2570 guests, 94 members online
