Thread started 24 Jun 2007 (Sunday) 00:25
Thoughts on reusing a flash battery pack
Canuck
Joined May 2003
Jun 24, 2007 00:25 |  #1
Hi all,
This is kind of wild. I've been dabbling with electronics since '94 and this leads me to the current thought. The batteries on the Quantum flash unit I have finally gave up the ghost. It seems to me that upon disassembly there are 3x 1.2 VDC (Volts Direct Current) batteries that power it. So they are wired for power (can't keep straight parallel/series) and leads me to place the voltage necessary at 3.6VDC. However, it also takes 4x AAA giving you 6 VDC. What I am thinking is that it accepts up to 6 VDC, so I was wondering if anyone has has a go with this? It certainly seems cheaper to replace the batteries and put it back in service. Mind you this hooks up to a SunPak Auto 36 Thyristor which is ancient, but if it still works (which it does) then use it. I'm also dabbling with a much higher current than what it originally had as this will provide me longer life/more flashes. It is the voltage; not current that matters in this case as it will only take what it needs.
mids1999
Mar 21, 2008 23:22 |  #2
I know this is an old thread but I found the answer for those who want to replace the batteries in their quantums.
The batteries are Hawker Energy CYCLON batteries which are interestingly 2v rechargable batteries.
Cyclon 6VD Rail Pack (0810-0102) SLA Battery Pack, 6V 2.5Ah $25.42 in the case of the quantum battery 1.
I am probaby going to attemp to use these batteries in my battery 1 and make my own enclosure. Which should give me plenty of capacity.
3 x Cyclon E Cell (0850-0004) Sealed Lead Acid Battery, 2V 8.0Ah at $11.95 ea.
You can also get then at http://shopping.microb​attery.com/s.nl/sc.2/c​ategory.704/.f (external link)
1,794 views & 0 likes for this thread, 2 members have posted to it.
1480 guests, 132 members online
