Thread started 25 Jun 2007 (Monday) 07:35
50mm means 80mm in digital, what about 75-300?
emre2006
Jun 25, 2007 07:35 |  #1
I hope this is not a stupid question...
When canon sells the EF 75-300mm f/4-5.6 USM III, are they referring to the 35mm film standard by saying 75 300mm? What does this make this lens when you use it on a digital camera?
Bodies: EOS30, EOS 40D, CONTAX 167 MT
Lenses: canon 70-200 f/4 L IS, carl zeiss 50mm 1.7, canon 50mm 1.8, 17-85 IS, 430EX
Other: Tripods and ball head by Benro, filters by Hoya, camera bag by Lowpro
Madweasel
Jun 25, 2007 07:39 |  #2
Prepare for the avalanche! This question always sets off a deluge.
In brief, the answer is if you are familiar with 35mm SLR photography, then multiplying focal lengths by 1.6 will give you an idea of the angular field to expect. If you've never been used to 35mm then you should ignore all this talk about multiplication factors.
The actual focal length doesn't change, only the angular field you get.
Mark.
lkrms
"stupidly long verbal diarrhoea"
Jun 25, 2007 07:42 |  #3
I found this confusing at first too.
All lenses are sold as per their actual focal length, i.e. a 50mm lens has a focal length of 50mm. But a 50mm lens on a "1.6 crop" camera (like a 400D, 30D, etc.) gives you the same field of view as a 80mm lens would on 35mm. Why? Because the sensor is 1.6 times smaller than 35mm film, and it therefore crops out part of the image that film would normally capture. So multiply by 1.6 to get numbers that make sense if you're used to film shooting.
Of course, a 50mm lens on a medium format camera would be like a wide-angle lens on 35mm ;-)a It's all relative ...
Luke
Headshot photographer Sydney and Newcastle (external link) | Twitter (external link) | Facebook (external link) | Blog (external link)
vash
Jun 25, 2007 07:45 |  #4
Yes, to your first question.
The answer to the second depends on the camera body.
Generally you multiply by 1.6 to get the effect of the smaller sensor of the camera. Of
course this differs if you have a full frame sensor or if you have a 1.5.
emre2006
Jun 25, 2007 07:45 |  #5
Ok I understand it now. Thanks for both of you.
emre2006
Jun 25, 2007 07:47 |  #6
vash wrote in post #3435577 (external link)
What about in the case of a rebel xt (350d)?
I have the following lenses:
50mm USM 1.8 II
75-300mm USM f4 III
28-90 USM
lkrms
Jun 25, 2007 07:49 |  #7
The Rebel XT is a 1.6 crop camera.
Luke
pakomo
Jun 25, 2007 07:52 |  #8
emre2006 wrote in post #3435586 (external link)
50mm USM 1.8 II
75-300mm USM f4 III
28-90 USM
As 350D is a 1.6 crop camera, this was answered by madweasel :)
Madweasel wrote in post #3435554 (external link)
... multiplying focal lengths by 1.6 will give you an idea of the angular field to expect.
Patrick Kofod Mogensen
Canon EOS 400D + BG-E3
16-35mm f/2.8L I,
85mm f/1.8, 18-55mm f/3.5-5.6 | 430EX + Omni-Bounce
Vitruvius
"oh god it burns!"
Jun 25, 2007 08:06 |  #9
so your 50mm will have a field of view similar to an 80mm, your 75-300 will have a FoV similar to a 120-480mm, and the 28-90 will be like a 45-144
jr_senator
Jun 25, 2007 08:29 |  #10
emre2006 wrote in post #3435546 (external link)
Yes,...
No! Canon is refering to the focal length of the lens. Type of camera has nothing to do with it.
Tapeman
Sliced Bread
Joined Jan 2004
Jun 25, 2007 08:35 |  #11
The focal length of a lens does not change on different camera bodies, but the field of view may.
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
emre2006
Jun 25, 2007 08:44 |  #12
Ok, please let me know if I understand this correctly then...
If you have a lens at 300m on a digital rebel xt, this means the lens is producing a 300mm FOV but the camera can only capture a smaller area of the bigger picture the lens is producing w(1/1.6=0.625) ,which is actually a CROP FROM the 300mm image. So you don't exactly have a 400 something mm lens but its just like taking a picture and cropping it with photosohop to its 0.625 size. ?
PS: I have quickly made an illustration of what I understood from the discussion, please tell me if its correct.
rowdyred94
Jun 25, 2007 10:07 |  #13
Looks like you have it figured out. Here's some more info.
http://digital-photography-school.com/blog/crop-factor-explained/ (external link)
http://www.cambridgein​colour.com …al-camera-sensor-size.htm (external link)
~ Clint :: Galleries (external link) ::
emre2006
Jun 25, 2007 12:11 |  #14
Thanks for the websites, they are very interesting...especial​ly this part:
mage information is never ideal, however it does have its advantages. Nearly all lenses are sharpest at their centers, while quality degrades progressively toward to the edges. This means that a cropped sensor effectively discards the lowest quality portions of the image, which is quite useful when using low quality lenses (as these typically have the worst edge quality).
00silvergt
"some dorky title"
Jun 25, 2007 12:59 |  #15
Field of View is the measurement of what the camera sees and can record using a 35mm film or "fullsized" CMOS sensor a reference source. That being said, the CMOS sensors in these "crop" cameras use a sensor smaller than the size of a frame of 35mm film. So obviously, you will not be able to record the same FOV (field of view). It is like using a projector and displaying on a screen that's too small for the projected image, some of it gets cropped out.
Since these crop cameras use a sensor 60 % of the size of a 35mm film/full frame, the focal lengths are multiplied by 1.6 in order to get the accurate focal length equivalent.
"Ne nuntium necare"
"We are building a fighting force of extraordinary magnitude. We forge our traditions from
the spirits of our ancestors. You have our gratitude."
https://photography-on-the.net …rgt/newlogo.jpg​%5B/IMG%5D
1,761 views & 0 likes for this thread, 11 members have posted to it.
1128 guests, 167 members online
