I'd like to get a battery pack for my flash, and have no experience shopping for these. If any wedding photographers can help me, I'd appreciate it. I can't afford the Quantum Turbo, so that's not an option.
JohnPelafigue Junior Member 20 posts Joined Apr 2004 More info | Jun 02, 2004 21:15 | #1 I'd like to get a battery pack for my flash, and have no experience shopping for these. If any wedding photographers can help me, I'd appreciate it. I can't afford the Quantum Turbo, so that's not an option.
JuhaL Mostly Lurking 18 posts Joined Dec 2002 More info | Jun 02, 2004 22:07 | #2 power for your 550ex flash
Jun 02, 2004 22:11 | #3 Thanks, but no can do. I'm on a tripod.
yallcome Member 205 posts Joined Jun 2003 Location: Suffolk, UK More info | Jun 03, 2004 02:25 | #4 Try here and modify to suit your voltage and needs
scottbergerphoto Cream of the Crop 5,429 posts Likes: 1 Joined Jun 2003 Location: Brooklyn, NY, USA More info | Jun 03, 2004 07:15 | #5 Quantum makes a number of battery packs that will work with the 550EX via the high voltage jack. You buy the pack and the corresponding cable for the 550. I use two Turbo Z's for my Nikon, Canon and Quantum flashes. You can find them at One World, One Voice Against Terror,
defordphoto MKIII Aficionado 9,888 posts Likes: 3 Joined Oct 2002 Location: Pacific Northwest More info | Jun 03, 2004 08:48 | #6 Try this one too: http://www.digitalcamerabattery.com/ defordphoto | Celebrating the art of photography®
Jun 03, 2004 10:49 | #7 Thanks for both replies. Quantum seems like a good company which supports its products.
NGrinerPhoto Senior Member 489 posts Joined May 2004 Location: Columbia, MD More info | Jun 03, 2004 12:32 | #8 http://www.powersource.org …ce/files/35mmbattery.html
rodbunn Member 240 posts Joined Mar 2003 Location: Santa Clarita, Ca More info | Jun 03, 2004 12:43 | #9 I use the Canon Transistor Pack
leony Member 197 posts Joined Dec 2002 Location: New Jersey, US More info | Jun 04, 2004 17:06 | #10 i second the transistor pack from Canon. It takes 6 AA batteries in the pack. NYC Area | www.studioly.com
Jun 04, 2004 17:49 | #11 Perhaps, but that makes the total cost over $200, after buying batteries and recharging unit, and you can only re-charge 4 batteries at a time, leaving you with two more to do afterward.
leony Member 197 posts Joined Dec 2002 Location: New Jersey, US More info | Jun 04, 2004 20:08 | #12 http://www.radioshack.com …=CTLG&product%5Fid=23-422 NYC Area | www.studioly.com
Jun 04, 2004 20:14 | #13 I'm referring to the six "C" batteries, not AA.
leony Member 197 posts Joined Dec 2002 Location: New Jersey, US More info | Jun 04, 2004 20:19 | #14 this is the one i use.... btw - 6 C cells is like a decent tripod in weight.... NYC Area | www.studioly.com
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | Jun 04, 2004 20:23 | #15 leony wrote: Transistor pack gives out higher mAh that is fed directly to the capacitor (it plugs in from the side plug on the 550EX) and not only gives you more flashes but also gives you a recycle of 1-2 seconds at full power - something only Quantum's TURBO batery does, and it's not cheaper than $200 - it's $450+. Isn't the Canon transistor pack simply a big set of batteries running into a current source transistor circuit?
| Latest registered member is bzguy 1611 guests, 184 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
