Thread started 25 Jun 2007 (Monday) 20:19
Need help installing a SATA external drive
danpass
Jun 25, 2007 20:19 |  #1
Seems like the most appropriate place - Ok, here is the deal.
I purchased an external case for a backup drive and purchased the new drive, purposely a SATA drive for use in a future tower.
My current computer is all IDE so I cannot simply install the drive in the tower to then setup the partition, etc.
What are the tricks to doing it thru the USB hookup?
The computer doesn't recognize a mass storage device because it is obviously not partitioned yet but it does recognize the 'case' connection.
running WinXPsp2
thanks,
dan
Dan
Gallery (external link) | Gear/Feedback
Zepher
Joined Nov 2005
Jun 25, 2007 20:24 |  #2
Right Click on My computer, Select Manage, Go to Disk Management, click drive and make your partitions.
Manny Desantos
Intel C2Q Q6600 3.06Ghz, 8GB Ram, 8.1TB, XFX HD5850, Windows 7 Ultimate 64bit, PS CS4 EXT (external link)
Canon 40D, EF 28-70L, 2x Canon XH-A1 HDV, Canon HV30 HDV
❶_______________
Tsmith
Formerly known as Bluedog_XT
Jun 25, 2007 20:36 |  #3
You might need to initialize it first using Zepher's method.
danpass
Jun 25, 2007 20:36 |  #4
Zepher wrote in post #3439465 (external link)
Its not showing up there.
I did manage to get it to say 'unknown device' so I am making progress LOL
any other tricks?
Dan
Tsmith
Jun 25, 2007 20:48 |  #5
Tsmith wrote in post #3439533 (external link)
Do you have this option?
Zepher
Joined Nov 2005
Jun 25, 2007 20:52 |  #6
strange. It should load the USB mass Storage driver and then you should see it in Disk Management. And ya, you will need to probably initialize the drive, forgot about that step, thanks Tsmith.
Manny Desantos
❶_______________
danpass
Jun 25, 2007 21:27 |  #7
Well I finally got Disk Management to recognize the drive. But when I initialize it it runs for abut 2min then says "Unexpected error" then lists the drive as 'Basic - Unreadable'
Dan
Time ­ Thief
Jun 25, 2007 23:35 |  #8
NOT a computer GURU but does it need to be formatted? Hopefully someone with more knowledge can chime in here.
40D, 20D, 24-105 4.0L, 24 2.8, 70-200 2.8L, 18-55 kit lens, 2 x 430ex's, way too many extras to list and even more that I need :mrgreen:
DPP tutorials: http://www.usa.canon.c​om/content/dpp2/index.​html (external link)
NeoDude
Gallery: 12 photos
Jun 26, 2007 03:18 |  #9
What size of PSU do you have and what else do you have running off it?
In2Photos
Jun 26, 2007 07:16 as a reply to  @ NeoDude's post |  #10
If all else fails you could always get a PCI card with SATA connections and hook it up inside your tower to format and then switch it to the external case.
Current Gear and Feedback
danpass
Jun 26, 2007 08:26 |  #11
In2Photos wrote in post #3441769 (external link)
I think there might be a problem with the external case.
It took a while for the computer to recognize the specific case (it had already recognized the USB Mass Storage device) and in the moment (of course) that I unplugged it, it began to recognize the "eSATA blah blah blah".
So I plugged it back but I was too late. It gave me the error message "unable to recognize drive" or something like that.
Well I plugged it in again and FINALLY the Logical Disk Manager recognized the drive but every time I try to initialize it, it crashes.
I never got the little popup again about "eSATA ... ". I did try uninstalling the USB driver and stuff and I also I tried it on my laptop as well
Should I return the drive and/or the case?
I was going to stick it in a work computer which has SATA internals and do it that way then back into the external case.
But I'm tempted just to go back to Tiger Direct without touching anything, exchange it all, and start over just in case
IMAGE: http://i28.photobucket.com/albums/c222/danpass/smilies/smiley_abused.gif
_
Dan
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jun 26, 2007 10:41 |  #12
Sounds like either the case or the drive is sketchy..
I'd do exactly that and dump it all.
CDS' HOT LINKS
Sathi
Jun 26, 2007 12:28 |  #13
There should be a jumper on the back of your SATA drive. It is there to throttle the SATA drive to 1.5GB/s. Perhaps it is set to 3GB/s and your enclosure does not support this configuration?
20d / Tamron 28-75 2.8 / Canon 10-22 / Canon 100mm macro
xpsentity
Jun 26, 2007 12:40 as a reply to  @ Sathi's post |  #14
Download the initialization software from the manufacturer. It will recognize, initialize, and format the drive. It's usually called (MFGXXX) Disk Utility or whatever.
That's the way I've always done it at least - like... 75 times.
Black boxes, glass shards
http://entityzero.devi​antart.com (external link)
danpass
Jun 26, 2007 21:23 |  #15
Ok, well I exchanged both items.
Its formatting now. This time Disk Management gave me a popup for initializing the drive.
Don't know if it was the case or the drive LOL
_
Dan
1,847 views & 0 likes for this thread, 9 members have posted to it.
2716 guests, 155 members online
