GenEOS wrote:
We have a Meade scope and I have rigged a counter balance for the weight of the D60. Now I guess I can try the Mark II. Problem is, I need to rig a camera support. The Meade just isn't strong enough at the t-adapter connection to support a DSLR.
I have not bought the focuser for it, but I don't know if it would help. The Meade scope just has too much slop in the adjustments, slewing etc....
The Meade ETX T-adapter can barely handle the weight of a SLR camera in prime focus. With eyepiece projection (needed in photographing planets) you will end up with a much longer cantilever arm with the full weight of the camera hanging at the end of it all. The result is that T-adapter tends to flex and the fork mount clutch begin to slip. Plus the probability that the RA motor may not be able to handle all this weights and counter-weights. The higher magnification also makes the FOV much narrower. All these make locating and tracking just about impossible.
For photographing planets I use a 6" refractor with a 2" draw tube focuser on a HEQ5. The focuser is driven from a geared stepping motor extracted from an old Epson printer, giving very fine focusing movement. The whole assembly still droops a little after I attached the eyepiece projection tube + D60, but most of the time I can re-acquire a bright planet by nudging the camera around, then the real fun of trying to center and focus begins. Like I said before, it's a real pain.
Ken
