Thread started 28 Jun 2007 (Thursday) 22:56
My Experience with Eclipse2 on a 5D
jdkeck
Jun 28, 2007 22:56 |  #1
I originally posted in this thread, https://photography-on-the.net/forum/showthre​ad.php?t=280062 , about my experience with Eclipse2 on a 5D sensor. I tried using the Eclipse2 again with similar results, smears and residue from the Eclipse2 on the sensor. While I wouldn’t blindly recommend this, I was able to clean the smears by carefully breathing into the chamber to add condensing moisture on the sensor and gently wiping with a clean PecPad on the spatula.
I redid the test of a drop on a UV filter and there was some residue left after evaporating, it was just difficult to see on the clear filter and I may have missed it the first time I tried it. Repeating the test on an ND 0.9 filter left the same residue, just easier to see. Using a PecPad on the spatula as recommended for the sensor left the same smears and spots when the spatula was stopped. I'm convinced at this point that either the Eclipse2 is contaminated or it doesn't evaporate as cleanly as Eclipse. I have used the Copperhill method with original Eclipse on my 20D successfully in the past, smears and residue were never a problem.
Original Eclipse has been ordered and should arrive next Tuesday. I'll also try the evaporation test on the ND filter for comparison. I’ll post the results after my next cleaning attempt.
Jeff
Life is not measured by the number breaths we take but by the moments that take our breath away.
I ­ Simonius
Weather Sealed Photographer
Gallery: 19 photos
Location: On a Small Blue Planet with Small Blue People With Small Blue Eyes
Jun 29, 2007 03:14 |  #2
jdkeck wrote in post #3457561 (external link)
Jeff
Looking forward to seeing the results:)
Veni, Vidi, Snappi
Website  (external link) My Gear ---- (external link)
Tsmith
Formerly known as Bluedog_XT
Jun 29, 2007 07:15 |  #3
Yeah I'd be interested in seeing the results also.
TomHuckWa
Joined Jun 2005
Jun 29, 2007 09:32 |  #4
Me too. Interesting
Please speak slowly and distinctly. I have a wife, AND a computer, I don't need any more confusion in my life.
I wanted to be a nude photographer, but when I went outside naked, everyone pointed and laughed, so I gave it up.
Ballast
Jun 29, 2007 10:20 |  #5
I was just about to order some cleaning fluid since my rocket blower can't seem to clean my 30D sensor.
I don't want to wait (I want a clean sensor), but now I'm going to so I can see how your testing works out.
kster
Jun 29, 2007 10:26 |  #6
Isn't Eclipse E2 no longer recommended for the 5D sensor?
1DmkIII and some lenses
ticounne
Jun 29, 2007 10:57 |  #7
I have a 5D and clean my sensor with Eclipse 2 without problems using the Copperhill method. No residue.
Maybee your solution is contaminated???
Jean
Lots of equipment, no money and no time.
1Dmark IV, 1DmarkIII, 5D. 17-40L 4.0, 24-70L 2.8, 50 1.4, 70-200L 2.8 IS, 85L 1.2, 100 2.8 macro, 100-400L 4.5-5.6 IS, 300L 2.8 IS, 300-800 5.6.
davesrose
Title Fairy still hasn't visited me!
Jun 29, 2007 11:02 |  #8
kster wrote in post #3459808 (external link)
PS has now changed their recommendation back to Eclipse for the 5D. I bought E2 when I first got my 5D (at the time, that was the recommended solution). PS says that if E2 isn't giving your problems, then you can continue to use it. Just as they said for the original eclipse on the 5D (back when E2 was just being introduced).
Interesting about the residue issues. Maybe environment has a lot to do with a solution being contaminated or something?? I haven't had problems using one swab and E2. Other people say they have to go through 8 swabs to get their 5D clean.....so it just seems that YMMV for any method:lol:
Canon 5D mk IV
EF 135mm 2.0L, EF 70-200mm 2.8L IS II, EF 24-70 2.8L II, EF 50mm 1.4, EF 100mm 2.8L Macro, EF 16-35mm 4L IS, Sigma 150-600mm C, 580EX, 600EX-RT, MeFoto Globetrotter tripod, grips, Black Rapid RS-7, CAMS plate and strap system, Lowepro Flipside 500 AW, and a few other things...
smugmug (external link)
jdkeck
Sep 20, 2007 10:39 |  #9
So much for a timely response to my original post, too busy using the camera to take pictures and not cleaning it :D.
I tried a drop of Eclipse from the fresh bottle on the ND0.9 filter. there was small ring after evaporating, noticeable but less than Eclipse2. Eclipse evaporates faster than Eclipse2. Using Eclipse with the Copperhill Method worked well. As usual, at least for me, it took several cleanings to get all the dust removed. This is viewing the sensor at f22. At f14, where I would normally shoot landscapes, the it would have been clear after the 2nd swabbing.
On one attempt, I had too much Eclipse on the PecPad. 3 drops instead of 2 - my error, sometimes the bottle sems to have mind of its own. That left some residue at the edges that was visible on the sensor as well as the image on the computer. I just mention this as a reminder that too much Eclipse can cause problems. The residue was easily removed with properly dampened PecPad.
The sensor is now clean and still scratch free.
Jeff
stevieboy378
Sep 20, 2007 13:33 |  #10
I've just got my 5D back from Canon, and my bank balance is £180 lighter, after wrecking the IR filter whilst wet cleaning with original Eclipse fluid and Photosol swabs.
I won't be using Eclipse or Eclipse2 again - its dry cleaning ( rocket blower and Arctic Butterfly ) only for me, plus the occasional trip to the local Canon dealer, where I'll let them wet clean it . . .
EOS 5D & 350D
EF 24-105L IS | EF 70-200f4L | EF 17-40 f4 L | EF 50 f1.4 USM
430EX Speedlite
Epson P-2000 | Photoshop CS3 | Lightroom 2
I ­ Simonius
Gallery: 19 photos
Sep 20, 2007 15:09 |  #11
jdkeck wrote in post #3970987 (external link)
On one attempt, I had too much Eclipse on the PecPad. The residue was easily removed with properly dampened PecPad.
Jeff
I thought the warremty was invalid if we use pecpads instead of sensor swabs? ( did I read that wrong?)
stevieboy378 wrote in post #3971892 (external link)
What about PS guarantee? Did you do something to invalidate it or are you claiming?
Veni, Vidi, Snappi
jdkeck
Sep 20, 2007 15:44 |  #12
I Simonius wrote in post #3972534 (external link)
From the Copperhill Website,
"The "Copperhill" method uses PecPads, whereas the traditional method uses Sensor Swabs. If you can prove to us through a reputable 3rd party that the PecPad material was the sole cause of damaging your AA-filter, we will have it replaced at our expense. That's how confident we are in the safety of the Copperhill tools and regimen."
First page of their cleaning procedure.
I've used this procedure on my 20D and my 5D. The results are positive and ther hasn't been any sensor damage. When I said there was too much Eclipse of the PecPad, there wasn't enough to squeeze liquid out. The PecPad should just be damp enough pick up the dust particles, you're not wet mopping the floor :rolleyes: . I've tried a dry PecPad on the swab and it didn't do anything except move particles around. At least it didn't do any damage :oops: .
Jeff
I ­ Simonius
Gallery: 19 photos
Sep 20, 2007 17:14 |  #13
jdkeck wrote in post #3972778 (external link)
Jeff
I was referringto the PS guarantee but if the poster was using copperhill then sure that's the one that matters
Veni, Vidi, Snappi
puttick
Joined Mar 2002
Sep 20, 2007 17:21 as a reply to  @ I Simonius's post |  #14
Dust Aid
Just bought, and used, the Dust-Aid system on my 5D. Easy, quick, dry, works as it says on the tin (literally)
Nigel
Nigel Puttick
North Yorkshire, UK
jdizzle
Darth Noink
Sep 20, 2007 17:26 |  #15
That is so weird. I haven't had that problem since I've been using the eclipse solution. Here is my process:
1-Rocket blower- to blow off any dust.
2-Eclipse and pads for doing my wet cleaning procedure.
3-Dust Aid- For any spots I missed and anything left by the sensor swab.
I haven't had any problems with this solution and it works for me all the time.
3,769 views & 0 likes for this thread, 14 members have posted to it.
2813 guests, 158 members online
