Thread started 05 Jun 2004 (Saturday) 11:04
Seeking clarification on Aperture Values on Rebel
csondagar
Joined Mar 2004
Jun 05, 2004 11:04 |  #1
bannedPermanently
If a lens is marked 18mm-55mm f3.5-f5.6, and the Rebel Aperture Value range is f1.0-f91 then does it mean that with 18mm I can use AV from f3.5 to f91? And with 55mm (zoomed) I can use AV from f5.6 to f91?
My Website (external link) | flickr (external link) | 500px (external link) | 7D, EF 50mm f/1.8, EF 24-105mm f/4L IS USM, EF 75-300mm f/4-5.6 III USM | Speedlite 430EX | Reflector Disk 5-in-1 110cm
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jun 05, 2004 11:16 |  #2
... Well yes and no..
It turns out that "aperture value" is a different number entirely from the "f/stop" which are the numbers we are familiar with.. like f/3.4 - f/5.6... I doubt that there is a lens that will stop down to "f/91"
You will get the lenses full f/stop range though.. starting at the widest f/3.5-f/5.6... you would need to look up the lens info to see how far you can stop it down..
Hope this helps.
CDS' HOT LINKS
Calis
Joined Jan 2004
Jun 05, 2004 12:01 |  #3
I've got mine in my hand now and the EF-S 18-55 will stop down to f/29
Phil
www.pbase.com/calis (external link)
arumdevil
Joined May 2004
Jun 05, 2004 16:01 |  #4
This is something I was not aware of before, but I noticed this in the exif data:
Exposure time: 1/4000 sec
F-Stop: 3.5
then farther down there is
Shutter Speed: 1/4000
Aperture Value: 3.6
So why are there two? and which one is the settings I made on the camera?
cheers,
Regards, arum.
"Originality is merely an illusion" M.C.Escher
6D | 50 f/1.4 USM | 28 f/1.8 USM | 24 f/2.8 | 70-210 f/4 | YN560-II
arumdevil
Joined May 2004
Jun 05, 2004 16:04 |  #5
Oh, and bye the way - the EFS 18-55 will stop down to 22 @ 18mm and 36 @ 55mm
Regards, arum.
Calis
Joined Jan 2004
Jun 05, 2004 16:50 |  #6
Which would make sense, as I didn't think to check at different focal lengths and the f29 I got was at around 35mm.
Phil
2,142 views & 0 likes for this thread, 4 members have posted to it.
2464 guests, 96 members online
