Thread started 01 Jul 2007 (Sunday) 04:48
'some' TIFs appearing as 'X' in DPP, other TIFs display correct thumbnail. Why??
andrewaaa5
Joined Sep 2004
Jul 01, 2007 04:48 |  #1
Does anyone know why some of my TIFs appear as an 'x' in DPP 3.0.1.5 and others show correctly, and any advise on how to fix this?
see below:
andrew crighton
website -- > www.butterpeanut.com (external link)
flickr -- > flickr/photos/andrewaa​a5 (external link)
kevin_c
Jul 01, 2007 05:17 |  #2
Can you open them ok? - they may be corrupt...
-- K e v i n --
Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4
Canon EOS 3, 24-105L, 135L
andrewaaa5
Joined Sep 2004
Jul 01, 2007 05:38 |  #3
ooops, sorry, i should have added more detail. I can open the TIF in Irfan View and WinFax view, LR and PS3 perfectly... I also saved it as a JPG in PS3 and even that opens in DPP... It is the horse photo below, but the TIF does not show, but other TIFs do show....
andrew crighton
kevin_c
Jul 01, 2007 05:48 |  #4
Not come across this myself with a tif file, I have had a couple of corrupt jpegs in the past though.
Can you open the 'faulty' tif file and save it as another tif, is this then readable in DPP?
-- K e v i n --
andrewaaa5
Joined Sep 2004
Jul 01, 2007 05:56 |  #5
kevin_c wrote in post #3468062 (external link)
I tried this also. It fails to show it DPP when i 're-save' the TIF. I do not think it is a faulty TIF. I recall someone talking about ICC Prifles when saving, or IPTC and how this may affect some images shown in DPP but I cannot see any options for the latter when I save the TIF is PS3, and do not have a good understanding of them...
andrew crighton
andrewaaa5
Joined Sep 2004
Jul 01, 2007 07:41 |  #6
To explain the generation of the TIF a bit better, I started in LightRoom with a CR2 > R/C > Edit in PS > did all my work > Save As > 'filename.tif'
Then I try to just look at the TIF in DPP and I get this big ugly 'x' (see first screen grab in thread number 1 above)
I just tried to replicate this with another CR2; started in LightRoom > RC > Edit in PS > did all my work > Save As > 'filename.tif'
But with this test I am able to see the TIF in DPP. My thoughts are now with your suggestion kevin_c, that the original TIF could be corrupted..
Does any one know if there is a limit on file size that DPP can thumbnail, as the TIF that dispalys as an 'x' is 57mb in size..?
andrew crighton
kevin_c
Jul 01, 2007 07:46 |  #7
What if you do a 'save as' with the 'faulty' tif file, in other words save it with another name (don't just rename it) - can DPP see it now? - It may be the cache of DPP keeping the original filename labeled as unreadable
-- K e v i n --
andrewaaa5
Joined Sep 2004
Jul 01, 2007 08:01 |  #8
kevin_c wrote in post #3468283 (external link)
i get this..... which kind of explains it :(.....
somehow the jpg I made from a 'save as' in PS works fine (luckily!...)
andrew crighton
kevin_c
Jul 01, 2007 08:06 |  #9
Oh dear... I assume you still have the original RAW file so I'd convert another if I were you :-) Although I'd still be tempted to rename it slightly to stop DPP's cache 'remembering' the original as faulty/corrupt.
-- K e v i n --
andrewaaa5
Joined Sep 2004
Jul 01, 2007 09:45 |  #10
yep, will give that a go.... i need to put my 'editing photos' hat on first :)
andrew crighton
C2S
Jul 01, 2007 12:12 |  #11
Could be the LZW-compression as well, I think DPP doesn't understand it. But I don't know whether you're using LZW when saving...
EOS 500D | Sigma 10-20mm EX | EF-S 18-55mm IS | EF 50mm f/1.8 II | Sigma 70-300mm macro | Tripod | CPL | 25% GND | 0.2% ND | Canon RC-1 | 430EX Speedlite
andrewaaa5
Joined Sep 2004
Jul 01, 2007 12:52 |  #12
well, i am not sure if PS remembers what the TIF was saved as last time, but when I opened it in PS, and did 'save as' again, it presented the following:
(not sure if these are in mem. of PS though....)
for this particular image i am not too concerned now that I have a high quality JPEG, but I don't want this to happen again with future TIFs, I am not able to replicate issue though..
andrew crighton
3,074 views & 0 likes for this thread, 3 members have posted to it.
2716 guests, 143 members online
