Again, these are full resolution crops without any manipulation, shot with my 10D, in Large JPG mode.
The camera was tripod mounted. I used a wired remote release to eliminate any camera shake from pressing the shutter release. Focal lengths were verified to be identical through the EXIF data, specifically, comparing 75mm to 75mm and 135mm to 135mm.
All exposures were done using only the center focus point, aiming at the window. Yes, I know that there is a fence there, but both the fence and the window were close enough to "infinity" that I used that anyway. All exposures were first set "out of focus" and the AF was allowed to find the focus itself.
To me, it looks as though that at 70mm focal length the images are just the same. My new $1700 lens shot just as well as the $350 one. ARRGH!At 135mm, the much cheaper 28-135 is clearly sharper. Note the patterns in the stucco and the white pipecap on the roof for the clearest example. DOUBLE ARRGH!!!
I asked the guy at Samys if there is any return if I am not happy with the results. He said there is no "test shooting" time allowed. Well, I am not happy. If it were you would you demand a refund, in spite to being told there was none? This is a VERY BIG bullet to bite.
28-135 at 70mm 125 at 6.7
![]() | MIME changed to 'text/html' | Content warning: script |
70-200 L at 70mm 125 at 6.7
28-135 at 135mm 125 at 6.7
70-200 L at 135mm 125 at 5.6
who dare saying they dont sharpen their photo!!
