Thread started 02 Jul 2007 (Monday) 11:05
Is This To Be Expected?
IrishKing
Jul 02, 2007 11:05 |  #1
I shot a Cardinal early yesterday evening using my Canon zoom lens 'IS' (70-300 mm) at 1/500th shutter speed, f stop F8.0 aperture, and 1250 ISO speed. The Cardinal turned out okay but it wasn't very sharp and lacked good detail.
tell me what I did wrong? what do I need to do in order to get excellent sharpness and good detail taking pics of wild birds with my zoom lens?
[FONT=Arial]
Canon 30D, Canon EF 70-300 mm 4-5.6 'IS' USM, Canon 28-135 mm 3.5-5.6 IS USM
GyRob
Jul 02, 2007 11:43 |  #2
your not close enough to the bird it is tiny conpared to the frame your showing.
also iso 100/ 200 will give more detail
Rob.
"The LensMaster Gimbal"
Madweasel
Jul 02, 2007 11:52 |  #3
It looks to me as though the camera has locked focus on the vertical pattern of the chair back, rendering the bird slightly out of focus.
Mark.
rowdyred94
Jul 02, 2007 11:56 |  #4
I think f/8 allowed enough DOF for the bird to be in focus, but it's quite underexposed You need to provide a background that's not bright white. Were you that far away that the bird was that small even at 300mm? It'd be nice if you'd fill out your signature so we know what you're shooting.
~ Clint :: Galleries (external link) ::
Tyreman
Jul 02, 2007 11:58 |  #5
A good 'pod,shutter release and lens for birding perhaps.
Cambridge, ON.
cosworth
I'm comfortable with my masculinity
Jul 02, 2007 12:01 |  #6
Also AV/TV mode saw mostly white and metered accordingly. No detail is because it's underexposed for the bird.
people will always try to stop you doing the right thing if it is unconventional
Full frame and some primes.
superdiver
Jul 02, 2007 12:33 |  #7
Not close enough to the bird, focused on the wrong place and maybe some camera shake involved as well...
What to do different...
1)Try and get closer...300mm is not that long when it comes to birding....
2)lower your ISO if possible to get more detail
3)use a tripod
4)use spot metering if you have it...
5)practice, practice, practice...
Not bad for first attempts, you will get better fast, especially if you keep posting and asking questions...
40D, davidalbertsonphotography.com
Newbie still learning
elader
Joined Nov 2005
Jul 02, 2007 12:43 |  #8
also dark bird on dark background.
lens looks fine.
Eric
FJR1300 rider
5D mkIII and 1D MkIII
16-35L | 24-105L | 70-200L f/2.8IS | 85 f/1.8 / 50 f.1,4
vetkrazy
Jul 02, 2007 12:49 |  #9
Were you using center point focus or all focus points? Which camera? Focus is obtained by differences in contrast. I think that maybe your camera meter was fooled by the white chair and the dark background. If you have zoombrowser you can check your focus point.
Wrap your ass in fiberglass.... You're only young once but you can be immature the rest of your life
http://vetkrazy.exposu​remanager.com/ (external link)
IrishKing
Jul 02, 2007 13:07 |  #10
Vetkrazy
First I have a new Canon 30D and I used only the center auto focus affair in Program mode. Is there a way to manually focus while in Program (P) mode?
IrishKing
Jul 02, 2007 13:11 |  #11
Gyrob and Superdiver
I would estimate that I was approimately 30 feet away from that bird when I shot that pic. Cardinals are very hard to get close to. Maybe a Canon 70-300 mm lens with 'IS' isn't the right tool.
do birding photographers use camo and netting to move in close to birds?
IrishKing
Jul 02, 2007 13:13 |  #12
Maybe I would be better off just turning off the auto focus feature on my lens and going manual mode.
nicksan
Man I Like to Fart
Jul 02, 2007 14:36 as a reply to  @ IrishKing's post |  #13
Maybe the bird was moving its head very quickly?
The chair seem to be in focus.
Any chance you misfired due to some shake?
If the bird wasn't moving, the IS should have actually helped you...well maybe not too much, but it definitely wouldn't have harmed you!
Mr. ­ Clean
Jul 02, 2007 14:39 |  #14
superdiver wrote in post #3474566 (external link)
3)use a tripod
Great advice right here. Alone, spot metering and 100mm more of FL, or just being closer would have made a world of difference.
Mike
some shots @ Zenfolio (external link)
IrishKing
Jul 02, 2007 14:45 as a reply to  @ nicksan's post |  #15
Nicksan
yes, there's always the possibility that I moved and not the bird.
Using a POD to keep the camera steady seems like a rather cumbersome process and also a pain to drag around and set up.
I think I will experiment with a monopod to see if that produces clearer and crisper shots.
Thanks all for the great advice. Much appreciated.
2,463 views & 0 likes for this thread, 18 members have posted to it.
489 guests, 122 members online
