Thread started 03 Jul 2007 (Tuesday) 19:59
Is it normal for a 70-300 lens IS USM to do this?
IrishKing
Jul 03, 2007 19:59 |  #1
I have a Canon 30D with a 70-300 IS USM lens. while trying to focus using auto focus in Program mode, the lens will suddenly go bananas by going out and back in again ending up completely out of focus. When it does this, it behaves like it's locked out of focus and the camera is useless. Is this normal behavior?
Canon 30D, Canon EF 70-300 mm 4-5.6 'IS' USM, Canon 28-135 mm 3.5-5.6 IS USM
shaneotool
Jul 03, 2007 20:01 |  #2
maybe it cant lock focus. What are you trying to focus on?
IrishKing
Jul 03, 2007 20:05 |  #3
Shane
When this has happened, I was usually trying to focus on a bird or some small animal.
does this lens freeze up when it can't lock in focus?
Stuperfox
Gallery: 12 photos
Jul 04, 2007 00:00 |  #4
Is image out of focus when you take a picture? If it is not, then it might just be the diopter might not be set for you eye. It might also be dirt or something on the cmos AF sensor. Have you tried different auto focus points?
"I work from awkwardness. By that I mean I don't arrange things. If I stand in front of something, instead of arranging it, I arrange myself" -Diane Arbus
EOS R6 MK II Gripped | EOS R6 | 24mm F1.4 | 35mm F1.8 IS | 50mm F1.8 | 135mm F2L | 15-35mm F2.8L IS | 24-70mm F2.8 II | 70-200mm F2.8L IS | 150-600mm F5-6.3 G2
Titus213
Jul 04, 2007 01:34 |  #5
Sounds like the camera is searching for focus and not finding it. It needs some contrast to achieve focus. If you are a bit off the bird or animal you could be trying to focus on a low/no contrast background. Use the center point only and see if that helps.
Dave
Perspiring photographer.
Goshawk
Jul 04, 2007 04:49 |  #6
Not to sure what you mean "camera useless", does it mean that even if you try to re-focus the lens still stay locked in one position?
All the obvious solutions/problems have been covered by previous replies to your thread.
Low light, low contrast, dirty lens contacts all can cause a lens to not work properly.
But if your lens lock after failing to focus and do not want to re-focus afterwards even if you point it somewhere else then it might need a service. I do not know this lens but know that some IS lenses needs the IS to be switched off when mounted on a tripod. So maybe try your lens with the IS switched off and see how it behaves.(even if not tripod mounted, as your IS might be playing up)
1D Mk III - 100mm 2.8 Macro - 24-70mm 2.8L - 70-200mm 2.8L IS - 500mm 4.0L IS - 430EX, 580EX II, ST-E2, Stroboframe, Quantum Turbo (external link)
http://www.flickr.com/​photos/deonnaude/ (external link)http://www.flickr.com/​photos/deonnaude/ (external link)
simwells
Jul 04, 2007 04:55 |  #7
From your gear list it seems to be your only lens, but is there any way you can try the body with another lens?
idlemonkey
Jul 04, 2007 11:01 as a reply to  @ simwells's post |  #8
Mine does this now and then on my 350D, mainly when there is lack of contrast or low light. All i do is aim off and try again ... usaually successfuly. I don't look at it as a problem ..... just something to get used to with this lens, seems to need a lot of light to get the best from it.
Not sure what you mean by the camera is useless tho?
IrishKing
Jul 04, 2007 12:00 |  #9
thanks everyone for your input. By the camera becoming 'useless', I meant that I couldn't get it to focus again after it locked up in a blurry out of focus condition. Kind of like a gun that jams and won't fire.
I am hoping that the 'IS' on this lens is not defective.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Jul 04, 2007 12:04 |  #10
I don't think IS has anything to do with AF, two different mechanisms. Body controls AF and tells IS to kick in, then moves AF back and forth.
IrishKing
Jul 04, 2007 12:18 |  #11
Simwells
I have another Canon lens, a 28-135 mm 3.5-5.6 IS USM but I haven't been using it to try to capture pics of birds because it doesn't have the reach of the 70-300.
I need a lot of reach unless I dress like Rambo and camo myself.
bmx43
Jul 04, 2007 12:27 |  #12
i've seen this on my 28-300 a few times. i've always found that the problem is that i have the 0.7m-00 vs 2.5m-00 switch in the wrong position. switch that and it's all good. does your lens have that option?
IrishKing
Jul 04, 2007 12:32 |  #13
bmx43
My 70-300 lens has an Image Stabilizer Mode No. 1 and 2 switch. I have kept it on the No 1 position and never switched to IS No. 2.
Guess I need to play around with the No 2 mode just to see what happens.
bmx43
Jul 04, 2007 12:36 as a reply to  @ IrishKing's post |  #14
yea, i have those switches as well, but also the 0.7m-oo or 2.5m-oo switch. sounds like you might not have that switch on that lens.
tekkie
Jul 04, 2007 12:38 |  #15
unless your taking panning shots, like turning from left to right while taking a pic of a moving car turning it to setting 2 is not going to help you in any regard whatsoever its only designed for that
what AF mode are you using? was it dark outside? how close were you? sounds to me like its either to close or it cant focus because of low light
I never had these problems with the lens when I had it
Canon 1DMKII, 7D, 5DMKII, 1D MKII
Canon 500L, 100-400L
, 70-200 2.8L, 17-40L, 24-105L, 24mm 2.8,50mm 1.4, 85mm 1.8, 135mm 2.8 SF, 100mm Macro
Canon 430 & 580 flashes
3,614 views & 0 likes for this thread, 12 members have posted to it.
489 guests, 122 members online
