The people in the "Understanding your camera's built-in metering" thread (here) have asked me to put technical questions and discussion elsewhere.
This thread is that elsewhere.
To start it off, I'll reply to one of the messages in that thread.
TMR is correct concerning my post. Shooting in Manual wouldn't be an issue when learning exposure if the Exif data showed you how much above/below the center line you shot your image at. (the amount +/- the center line is the equivalent to EC). The end result is that when you look at your Exif you have no idea if you shot using the camera's suggested metering, above it, below it, and by how much.
This isn't quite true, but it's close. The data is there but it takes a little work to use it.
In the "Maker Notes" section of the EXIF data is an entry for "Measured EV". This is the EV the meter read from the scene. It's present for the 30D and, I expect, for earlier models as well, but I can't verify that. This is present in the jpeg image generated by the camera, and probably the raw image as well (I haven't looked for the latter).
Unfortunately, the "Maker Notes" information isn't guaranteed to be transferred to postprocessed images. Rawshooter Essentials, for instance, seems to drop it on the floor. So you may have to go back to your originals to see it, and it's even possible that you'll have to set your camera to store RAW+jpeg.
Okay, so...how do you use it?
Well...EV is defined as log2(N^2/t) where "log2" means "base 2 logarithm", N is the f-number, and t is the exposure time in seconds. If you can't directly compute a base 2 logarithm, you can do so by computing log(x)/log(2). Source for all this: Wikipedia
The camera's meter seems to be yielding the EV based on ISO 4. A bit odd, but the math does appear to work out. So if you have the EV from the EXIF and the aperture and you want to compute the shutter speed the camera would have used (if you hadn't been in manual mode), you can use this formula:
s = N^2/(2^(EV + log2(ISO/100) + 4.644))
Similarly, if you have the EV and the shutter and want to compute the aperture, you can use this formula:
N = sqrt(s*2^(EV + log2(ISO/100) + 4.644))
Where did the magic number 4.644 come from? It's log2(100) - log2(4). In other words, it's basically the number of stops between ISO 100 and ISO 4 (which appears to be the ISO the camera's EV measurement is based on). And log2(ISO/100) is the number of stops difference between ISO 100 and the ISO you're using.
It's still probably going to be easier for most people to just use Av or Tv + exposure compensation than to go through the trouble to deal with the above, but it's there for anyone with the determination to use it.
