Thread started 05 Jul 2007 (Thursday) 20:26
Photoshop Image Processor Script Alert and Save error
Richard_Miami
the windbag plateau
Jul 05, 2007 20:26 |  #1
Help please... :(
I just recorded a simple action in PS CS 3. Three steps - Image Resize, Save and close.
I tested the action. It works perfectly.
Then I went to Bridge. Selected a File. Ran Tools/Photoshop/Image Processor. The new action is selected at the bottom of the Image Processor dialog box. Ran Image processor. It runs perfectly. The image has been resized and saved exactly as intended. EXCEPT I get this error message. WHY? If I select multiple images.. it still runs.. and yet I get the error message with multiple listing. A mystery.
Second, and even more annoying.. it saves in the wrong folder. I have "Save in same location" checked, yet when it runs, it puts it into an older folder. This wrong saving also happens only when using Image Processor.
Any help would be greatly appreciated.
I am the crispy noodle in the vegetarian salad of life
Gear
RSPhotoGallery.com (external link)
tim
Light Bringer
Jul 05, 2007 22:17 |  #2
You don't need to use an action at all. Just select the files in bridge, choose photoshop services -> image processor, enter your maximum dimensions, and hit go. If you need a specific ppi set it in the RAW convertor (assuming the files are RAW).
If you really want to run your action you need to use the photoshop services -> batch, not image processor.
I suspect the problem with image processor is it's already opened the file then you try to do it again, or you save and close it then it tries to do it again.
pturton
Joined May 2002
Jul 06, 2007 06:21 |  #3
Better yet, use Russell Brown's 123 Process from Bridge and set the ppi in its dialog.
http://www.russellbrow​n.com/tips_tech.html (external link)
Richard_Miami
the windbag plateau
Jul 06, 2007 06:51 |  #4
tim wrote in post #3494756 (external link)
Tim
Thanks. I was doing this to save the EXIF in my jpegs. For whatever reasons, I have been having trouble with that lately. Never did before. I will try your method and see if it works. I am sure it will! As for the Image Processor, I will check to see if it is "saving twice" ie: once in the action and once thru the processor...that might explain why the action works properly and the Image Processor throws the error message. Ain't technology wonderful?
Gear
Richard_Miami
the windbag plateau
Jul 06, 2007 06:52 |  #5
pturton wrote in post #3496161 (external link)
Pturton
Thank you for the link. It looks like that website is going to take some time to review, but worth the effort. One of these days I am going to learn Photoshop, and win the Nobel Prize on the same day! :D
Gear
tim
Light Bringer
Jul 06, 2007 08:52 |  #6
Richard_Miami wrote in post #3496261 (external link)
Tim
Image processor retains exif, try what I suggested and see :)
6,720 views & 0 likes for this thread, 3 members have posted to it.
2855 guests, 134 members online
