Hi guys,
I'm wondering how everyone posts images on the web. Now, I do graphics for living so I'm definitely an advanced Photoshop user but I'm doing this particular thing the very best way? I have no idea...
This is what I do: I adjust the large image for color balance, levels, contrast and other stuff, may sharpen it a bit, and crop it. Then I reduce the image size, make sure it is 72 dpi RGB at whatever pixel size I need it (usually both sides are bellow 600 pixels) and then I Save For Web (Photoshop) where I may compress the file by about 10% to make the file size smaller and retain max image sharpness.
Now, when you have to "res up" or artificially size UP an image, there's a trick a lot of people use and that is to increase the image size by 110% in multiple steps. That seems to work best.
My question is:
Is there a similar trick that people use that help the image retain maximum possible quality when you size down because you definitely lose quality when you do that?
Cheers
