Thread started 06 Jul 2007 (Friday) 01:03
APERTURE USERS....I need a little help
August ­ 15 ­ Photography
Jul 06, 2007 01:03 |  #1
Ok so I am trying to get my library cleaned up a little. I have several projects created with similar names or similar subjects. i.e. Downtown, or Sports etc.. but like I said, each is its own project.
I want to clean it up a little and make one Project, for example "City" and put all things realated to city into seperate albums within that project and then delete all the original projects that the new albums came from.
However when I do this and go to delete the original project which I have just moved the images from, it tells me that there are other projects or albums that reference these files and if I delete the project the album images will be lost as well.
I have tested this theory with some not so important images and sure enough when I delete the original project, I lose the images in the new album as well, even if I uncheck the delete referenced files check box.
Is there a way I can move images in projects into albums, delete the original project and keep the images in the new album as to clean up my list of projects?????
Oooooh they have the internet on computers now. - Homer Simpson
Cameras and Computers
Tony-S
Jul 06, 2007 09:35 |  #2
Hmm. Well, I've never done that before. What you can do, I'm pretty certain, is to shift/command-click to select your images within a project that you want to move into a new project, then choose File-> Export-> Export Master... to save the original files somewhere on your hard drive. Then you could create a new Project within Aperture and just import those saved images into the new Project.
I'm not at home, so I cannot test this, but I think it will work.
Did you get your hard drive issue resolved?
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
blackviolet
Joined Apr 2004
Location: sydney, au (now in singapore for a few years)
Jul 06, 2007 09:45 |  #3
i've done that, and i do it all the time when i import projects from the laptop when i return from the road (and i havent put things into appropriate albums).
i do it in three steps, but it's not time consuming at all. basically, i create a new album in the destination project. i then move the file to the project. it will ask you if you want to move the master. lastly i do a shift-move from current album to the destination.
oblio
1dmkiii - 5dmkii -Leica M8/M6 - Mamiya 645AFDiii/zd
ModelMayhem (external link) | my (external link)flick (external link)r gallery (external link)
aRJun
Jul 06, 2007 12:02 |  #4
Keep the option Key pressed when you're moving the images(drag and drop)...I've done it from album to album and it worked great.
My Portfolio (external link)
Canon 7D |Canon Rebel XT | Canon 10-22 EF-S :D | Tamron 28-75 f2.8 XR Di LD |Sigma 70-300 APO DG Macro | Canon 50 f1.8 MkII | Zeikos Battery Grip |580 EX | Manfrotto 3021 BPRO Tripod | Manfrotto 488rc2 | Panosaurus
Jul 06, 2007 13:31 as a reply to  @ aRJun's post |  #5
awesome thanks guys I will try that when I get home. also I did get my hd issue fixed it worked in my neighbore mac so I got it all off and just bought a new hd just to be safe.
1,199 views & 0 likes for this thread, 4 members have posted to it.
2859 guests, 133 members online
