Thread started 06 Jul 2007 (Friday) 01:17
How to use old Canon Speedlite 277T with my XTi??
Viky
Jul 06, 2007 01:17 |  #1
I recently visited my in laws place, and my father in law dug out this completely unused Canon T70 Film SLR and Canon Speedlite 277T from the attic. I left the SLR behind, but took the Flash.
I've already tried it on my XTi and its almost 3times more powerful than the onboard flash, but, apart from just "flashing" the 277T, the XTi does not seem to be able to communicate with the flash regarding flash power or flash duration
HTTP response: 403 | MIME changed to 'text/html'
The flash unit has a 3-point contact for the Hot Shoe, whereas the camera body has a 5-point contact, effectively leaving 2 contacts on the camera "unused".
There are controls on the back of the flash wherein you can set the ISO speed from ISO25 to ISO 400, and Aperture from f/2 to f/22. Wherein ISO 25 with aperture f/22 gives the maximum flash power and ISO 400 with aperture f/2 giving the weakest flash power.
I unterstand these two units are generations apart and that i would never be able to get the same performance out of this unit as compared to the current generation Canon flashes, however i would like to see how best i could use this till i have saved enough for a better flash.
Can anybody shed some light on how to make the best use of this unit on my XTi. Any help would be highly appreciated
Here are a few pics of the combo together:
You first see a photo with your mind, and then capture it with your camera!
Canon - EOS 50D with BG-E2N | 10-22mm f/3.5 | 70-200mm f/4 L IS | 400mm f/5.6 L | Tamron - 17-50mm f/2.8 VC |Sigma 30mm f/1.4 EX | 150mm f/2.8 Macro EX | Misc - 430EX | OC-E3 | EF-12 | Kenko 2x TC | Panasonic FZ5. My Flickr Album (external link)
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Jul 06, 2007 01:41 |  #2
I have one of these, and it works perfectly with my 30D.
With the camera in manual simply set the ISO on the back of the flash to the same as the ISO on your camera, put it in F.No SET (left switch down) and match the aperture on the flash to your camera.
With a shutter speed if around 1/60 (I think the XT will sync up to 1/200th) point and shoot.
This is an Auto Thyristor style flash, so it calculates its own out put based on light reflected from the subject. Very effective and very reliable.
You can adjust flash exposure by adjusting the aperture on the flash or the camera :)
Did yours come with the extra wide diffuser flash panel and mock leather case?
So long and thanks for all the flash
cdifoto
Don't get pissy with me
Jul 06, 2007 01:46 |  #3
Looks like a Thyristor style flash. Just match up the ISO and aperture on the flash setting to that on the camera and you should get good exposures most every time.
Oops. Didn't read Moppie's post. He said the same thing. :)
bieber
Jul 06, 2007 01:49 |  #4
Yeah, match the settings up with those on your camera, and it works automatically. Although it's just going to give you head-on, direct light, which tends to be none-too-flattering. If you could move it off-camera (shoe cord?), it'd help a lot.
EOS 20D w/ BG-E2 grip
Nifty fifty, EF 28mm f/2.8, EF 70-200mm f/4L USM
Speedlights SB-25/SB-26/580EX, Pocket Wizards and such
My Gallery (external link)
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Jul 06, 2007 01:51 |  #5
cdifoto wrote in post #3495524 (external link)
I always had a suspesion I was being ignored...............
:p
For anyone worried about trigger voltage, I just tested mine.
It was a whooping great 3.6volts, making it safe for use with anything.
Viky
Jul 06, 2007 02:51 |  #6
Moppie wrote in post #3495512 (external link)
Thanks so much.:) I figured it should be used like this and tried it exactly the same way, but the exposures are a hit or miss... not always dependable:(
In the sense that if the scene is pretty low light, in Manual mode, on what do i base my exposure settings?? The camera meters for the available light and guides me to set an exposure based on that, but when i shoot, the flash fires, and there is "more" light than the camera expected, so there's over exposure:(
I even put the flash on the PROGRAM setting and the camera in P mode, set the same ISO on both, but still the same results, 70% over exposures, only about 20% keepers:(
Please help!
Yes, i got the diffuser panel and the mock leather case too!
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Jul 06, 2007 04:04 |  #7
Viky wrote in post #3495680 (external link)
It might be your dialing in to wide an apature, one the flash can't handle.
Can you post some examples?
Its also possible the flash is fualty, but lets totaly rule out user error first.
Viky
Jul 06, 2007 05:35 |  #8
sample pics
Moppie wrote in post #3495865 (external link)
I set my XTi with 18-55kitlens at 18mm in a very dark room. Set to Manual focus and klicked the following 3 pics:
1) Cam in Full Auto Mode - Pic taken with onboard flash, Exposute settings noted: f/3.5, 1/60sec, ISO 200.
IMAGE: http://i94.photobucket.com/albums/l96/rx100/1-1.jpg
2) Cam in TV mode - Pic taken with Onboard Flash, Exposute settings: f/3.5, 1/60sec, ISO 200.
IMAGE: http://i94.photobucket.com/albums/l96/rx100/2-2.jpg
3) Cam in TV mode - Pic taken with Canon 277T Flash, Settings on Flash : F No. SET mode, ISO 200, f/ 4, Exposute settings: f/3.5, 1/60sec, ISO 200.
IMAGE: http://i94.photobucket.com/albums/l96/rx100/3-2.jpg
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Jul 06, 2007 05:50 |  #9
Viky wrote in post #3496042 (external link)
3) Cam in TV mode -
Theres your problem.
The aperture on the camera, and the Flash need to be the same :)
Put the camera in Manaul, and the flash in F.no
Match settings for ISO and aperture on both, and try again. (I would shoot at ISO 100 to start with).
Also try starting on a subject with a smaller tonal range.
Its possible the the flash sensor dosn't cover a wide enough range, and also remember its trying to do the same thing a cameras meter does, i.e. make everything 18% grey. Hence why the dark things are bright, and the bright things are over exposed.
I just stuck mine on and had a play, camera in manual, 1/60 and ISO and aperture matching between camera and flash, with flash in F.No mode.
Worked pretty damn well, although it did tend to over expose slightly, by about 2/3's of a stop when dealing with whites and bright colours.
Easy fix was to shoot with the aperture on the camera stopped down about 1 stop from the setting on the flash.
The trick is to experiment with all the different possible combinations untill you find one that works.
I also had a play with the flash in Program mode.
Set ISO the same on flash and camera, and with camera in M dailed in 1/60th for shutter speed.
Then point at your subject and hit the test button on the flash. Mine fires a full power burst, then suggests an aperture setting for the camera.
I dailed this into the camera, and took a photo. It Produced a very nice exposure.
Viky
Jul 06, 2007 07:34 as a reply to  @ Moppie's post |  #10
WOW! Nice findings... i must try these setting tonight.
Thanks a ton for helping out!
Will revert back with the results tomorrow:D
Viky
Jul 07, 2007 01:02 as a reply to  @ Viky's post |  #11
The problem's been nailed!!!
As i was installing the Flash in the Hot Shoe to try the settings suggested by you, i noticed that the "optical window" in the front of the flash was very dirty and greasy:
IMAGE: http://i94.photobucket.com/albums/l96/rx100/4-1.jpg
So the first thing i did was clean it to a nice and shiny finish:)
Then i went about trying your settings, and this time in Manual mode I did not set exposure as per the cameras suggestions. Set the shutter at 1/60, ISO 100 and aperture at f/8... dialed the same settings on the flash in 'F.No. SET' mode, and here you go....
IMAGE: http://i94.photobucket.com/albums/l96/rx100/1-2.jpg
Not bad considering my son was only about 3ft away!
SECOND SHOT: This time i wanted to try the PROGRAM Mode, so leaving the ISO and shutter speed as earlier, i fired the test flash and the flash suggested an aperture value of f/5.6, dialed that on the camera and here you go...
IMAGE: http://i94.photobucket.com/albums/l96/rx100/2-3.jpg
Both the pics are straight out of the camera, only resized for web. So, i guess my "problem" now stands officially solved and all the credit goes to MOPPIE!!
Thanks a ton!
Viky
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Jul 07, 2007 08:04 |  #12
Viky wrote in post #3501071 (external link)
Thanks a ton!
Viky
Wahoooooo!!!
Welle done mate@
Plase note, the title under my avate if relevenat atn the moment. :lol::lol::lol::lol::lol:
Tragerman
Jul 07, 2007 09:51 |  #13
Glad this all worked out! One thing anyone with a modern EOS digital camera should consider when trying an old flash unit,is the trigger voltage of the flash. If it sends more than 6 volts to the camera, the flash should not be connected to the camera. This can cause serious damage to your camera. The 277T is safe to use.
If you want to try an old flash on your newer camera, check this site for trigger voltages. If it's listed over 6v, avoid the flash.
http://www.botzilla.co​m/photo/strobeVolts.ht​ml (external link)
-Mickey
http://tragerman.smugm​ug.com/ (external link)Canon 20D x2, Canon 10-22, Canon 70-200 2.8 L IS USM; Canon 17-55/2.8 IS USM, Tamron 28-75 2.8, Canon 28-135 IS, Canon 75-300 III USM (for sale), Canon D60 IR modified. 580EX, Sigma 500 DG Super. Save $5 on a Smug Mug membership - use this link: http://www.smugmug.com​/?referrer=TnVhKJgoJK8​gQ (external link)
bieber
Jul 07, 2007 10:35 |  #14
Any old Canon or Nikon flash should be safe to put on a modern camera, though. It's the off-brands you have to worry about (old Vivitars apparently have some really nasty trigger voltages)
Moppie
Moderator
Gallery: 24 photos
Joined Sep 2004
Jul 07, 2007 18:44 |  #15
Tragerman wrote in post #3502401 (external link)
;) Got it covered ;)
Moppie wrote in post #3495545 (external link)
19,421 views & 0 likes for this thread, 13 members have posted to it.
2295 guests, 136 members online
