Do I get more DPI when shooting in RAW? How can I get more DPI out of my 20D? Or how can I change the DPI to be 300?
Nightscape Senior Member 413 posts Joined Jun 2007 Location: Portland More info | Jul 06, 2007 09:38 | #1 Permanent banDo I get more DPI when shooting in RAW? How can I get more DPI out of my 20D? Or how can I change the DPI to be 300? Bodys: 1D classic | 20D and grip
droiby Member 62 posts Joined Apr 2007 Location: Sydney More info | Jul 06, 2007 09:41 | #2 Shooting RAW won't give you more DPI. DPI is only relevant when printing out an image in determining the final size of the print. Shooting RAW gives you the same number of pixels as shooting in JPEG at the largest resolution. Canon 30D | 70-200mm f/2.8L IS | 100mm f/2.8 macro | 50mm f/1.4 | 16-35mm f/2.8L | 17-55mm f/2.8 IS | 580EX
Radtech1 Everlasting Gobstopper 6,455 posts Likes: 38 Joined Jun 2003 Location: Trantor More info | Jul 06, 2007 09:41 | #3 1) No, shooting RAW will not give you more DPI. .
Jul 06, 2007 09:43 | #4 Permanent banPhotoshop CS (not 2 or 3) Bodys: 1D classic | 20D and grip
Radtech1 Everlasting Gobstopper 6,455 posts Likes: 38 Joined Jun 2003 Location: Trantor More info | Jul 06, 2007 09:48 | #5 Nightscape wrote in post #3496911 Photoshop CS (not 2 or 3) Good, same as what I use. I BELIEVE it is under the "Image" drop down, but I might be wrong - in any event, find the "Resize Image" menu. You will get the following dialog box:
Under the "RESOLUTION" heading, just change the value there to 300, and make sure "Pixels/inch" is selected, and that will change the DPI to 300. Thank you for allowing me to be of service. Rad .
kevin_c Cream of the Crop 5,745 posts Likes: 4 Joined Mar 2005 Location: Devon, England More info | Jul 06, 2007 10:29 | #6 It's actually PPI -- K e v i n --
| Latest registered member was a spammer, and banned as such! 2859 guests, 133 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
