Thread started 06 Jul 2007 (Friday) 20:28
Is there an action for this?
EOS ­ mE
Jul 06, 2007 20:28 |  #1
I recently shot a friend's wedding and they asked if I could give them the images in 5x7 format on a DVD.
I've just downloaded the TLR Crop Preset (external link) which works great one by one. But rather then going through it one by one, is there a way to run it in a batch and just do your selections then? This way I don't have to keep going File, Open, etc...
If anyone has any other action files I can use to easily and quickly crop it into 5x7.. plz do let me know. Thanks.
5DMKII Gripped | 30D Gripped | 50mm f1.4 | 24-70mm f2.8L | 70-200mm f2.8L IS | 430EX | 580EXIIhttps://photography-on-the.net/forum/showthre​ad.php?t=416554
My Reviews:
KATA 3N1 - 25PL Bag, Dolica CF Tripod ZX600B103
tim
Light Bringer
Jul 06, 2007 21:18 |  #2
Do it in ACR then batch them? Works for RAW or JPG in CS3.
Catnippants
Jul 06, 2007 22:27 as a reply to  @ tim's post |  #3
Crop to 5x7? It sounds to me like you are confusing resolution and dpi. Any pic with the proper aspect ratio can be made to print 5x7 simply by changing the dpi - and no cropping would be necessary. If however, you are trying to keep the dpi as is and just crop the center section of each pic so that it will print to 5x7, then that can be done too - although I suspect you won't be happy with the results unless all your pics are perfectly centered and all at the same distance from the subject.
I generally use irfanview (www.irfanview.com (external link)) for all my batch process cropping, resampling, etc. It's free and seems to work very well. Others may have other suggestions.
Mike
Canon 30D | 18-55mm/f3.5-5.6 | 50mm f/1.8 II | 28-135mm f/3.5-5.6 IS USM | 70-300mm f/4-5.4 IS USM | 420EX
howzitboy
Jul 06, 2007 23:01 |  #4
id do it manually so u can keep what needs to be kept. if u use some random program, it might crop off peoples heads or feet.
quick way, make a new window thats 5x7, then drag each image onto it, move till perfect, save then go one step back and drag next shot onto it.
http://onehourwedding.​blogspot.com/ (external link)
EOS ­ mE
Jul 07, 2007 01:50 |  #5
tim wrote in post #3500180 (external link)
Tim.. right now I only have CS2... don't have enough $ yet for CS3. Can that be done in CS2 ACR?
Catnippants wrote in post #3500505 (external link)
Mike
Thanks Mike.. I'm gonna have to check into irfanview... never heard of it, though.
howzitboy wrote in post #3500667 (external link)
though i want an automated process.. but i know that a semi automated will be more useful, so I can select where i want it cropped at. any semi-automated action for that though?
My Reviews:
brian_lewis67
Jul 07, 2007 06:42 as a reply to  @ EOS mE's post |  #6
Try http://www.download.co​m …3000-2192_4-10527244.html (external link) which I use regularly to get any ratio want
Canon 40D + Grip and Canon 350D + Grip | Canon 50mm f1.8 MkII | Sigma 17-70mm f2.8-4.5 DC Macro | Sigma 70-200mm f2.8 APO HSM EX | Sigma EX APO 1.4 TC |Sigma EX APO 2 x TC | Kenko extension Tubes | Canon 430EX Speedlite Flash
getabetterpic
Jul 07, 2007 16:06 |  #7
Depending on your hardware and the original resolution of the files, you could open say 10 or 20 at a time and crop them. That would do away with the file > open for each one.
30D w/grip, 28-105 f/3.5-4.5 NIS NL, 75-300 f/4-5.6 NL, 18-55 f/3.5-5.6 NL, 550EX, lots of energy and creativity.
canonphotog
Joined Nov 2005
Jul 07, 2007 18:50 |  #8
Recording your own action to crop or resize the images to 5 x 7 can be done easily in CS2. You just need to process on image from start to finish while recording the steps as an action. Then you use a batch process. Once you point it at your action and the folder where your images are you should be good to go. It's always a good idea to have the output go to a different folder.
Mind you, there is a bit more to setting up the batch process but not much. Adobes own help files can guide you through it successfully.
-Ken
Gear List|Kenny D. Photography (external link)
PJEP
Jul 08, 2007 04:20 |  #9
There are some resizing actions at http://www.1clickactio​ns.com/volume6.htm (external link) that are easy to batch for many images.
1,425 views & 0 likes for this thread, 8 members have posted to it.
2859 guests, 134 members online
