Thread started 09 Jun 2004 (Wednesday) 17:28
D Rebel Start up time? motocross??
mxer82
Joined May 2004
Jun 09, 2004 17:28 |  #1
How long till its ready to take a picture? Do you guys think i could successfully shoot motocross pictures with it
robertwgross
Joined Nov 2002
Jun 09, 2004 17:39 |  #2
All things considered, it is more a matter of the skill of the photographer rather than the camera itself. It depends on the lens and a host of other factors. The Digital Rebel is not exactly the very best camera for fast action like this, but it ought to do the job for a good photographer. The buffer size is a limitation.
---Bob Gross---
eric1
Joined May 2003
Jun 09, 2004 18:13 |  #3
Bobs right you can shoot anything if you use some planning. the buffer
is very small, i fill mine alot. you have to be a bit more selective with your shots. if you mean the time it takes to wake up from sleep mode,
you can adjust this in the settings. i usually just half press the shutter
every few seonds when i know the shot is coming. however this will shorten batt. life.
eric1
Eric
www.pbase.com/ericm (external link)
drisley
"What a Tool I am"
Joined Nov 2002
Jun 09, 2004 18:32 |  #4
The Rebel is great for action. Startup time is only a couple seconds, which I think is similar to the 10D.
I wish you could select AI Servo mode (although that is almost fully accomplished now with the russian firmware).
I shot this sequence with the Rebel of a diver on a 3M platform. That is very fast action indeed, probably faster than motocross. However, it took about 1hr of crappy shots before I got the hang of it.
I've seen some amazing auto racing pictures here with the Rebel.
EOS R6 Mark II - Sigma 50/1.4 Art - Sigma 14-24/2.8 Art - Canon EF 70-200/2.8L Mark III - Godox Xpro-C - Godox TT685C x2
ron ­ chappel
Honorary Moderator
Joined Sep 2003
Jun 09, 2004 19:26 |  #5
The 300D will do really well once you get used to it!! :D
BigRed450
Joined Dec 2003
Jun 09, 2004 19:38 |  #6
Its more about skill then equipment. I use a 10D with 100-400L and the buffer is not an issue at all as I seldom take more then one image at a time. Just depends on the sort of images you are looking for. You can check out my latest race pics http://users.air.on.ca …graphic/Proofs1​/index.htm (external link)
Jeff
CANON * EOS 1D MKIV * EOS 1D MKII *
* 100-400L IS, 300 f4L IS, 70-200 f2.8L IS, 24-70 f2.8L, 50 1.8 and alot of other gear.
JT Photographics (external link)
defordphoto
MKIII Aficionado
Joined Oct 2002
Jun 09, 2004 19:41 |  #7
The Rebel would do fair, but you'll have to be selective with your shots. Before acquiring the MKII I used the 10D and did quite well -- Got a magazine cover -- so it can be done. I was just a bit picky when I chose my shots to always try and have room in the buffer in case a super action shot came available.
Though the 10D is not as limited as the Rebel, it does have its limitations and I bumped into them from time to time. Now that I have the MKII, I now see how limited I really was.
As Bob said previously, the buffer will be your biggest enemy, and not having AI Servo focus will also be a limitation.
Other than that, as long as you choose your shots carefully, you can produce some awesome action shots with the Rebel.
BTW: I also recently acquired a Rebel. Haven't played with it much, but it's now in the bag.
defordphoto | Celebrating the art of photography®
SD500, 10D, 20D, 30D, 5D, 1DMKII, 1DMKIII
www.ussbaracing.com (external link) | www.rfmsports.com (external link) | www.nwfjcc.com (external link)
An austere and pleasant poetry of the real. Ansel Adams
1,953 views & 0 likes for this thread, 7 members have posted to it.
2471 guests, 106 members online
