Going beyond rule of thirds to techniques like the golden ratio; When you crop, what size ratio are you aiming for in your final print, ie, what is the ideal print size ratio?
Jul 08, 2007 14:38 | #1 Going beyond rule of thirds to techniques like the golden ratio; When you crop, what size ratio are you aiming for in your final print, ie, what is the ideal print size ratio? The things you do for yourself die with you, the things you do for others live forever.
kevin_c Cream of the Crop 5,745 posts Likes: 4 Joined Mar 2005 Location: Devon, England More info | Jul 09, 2007 09:38 | #2 For me it all depends upon the image - Mostly I leave mine in a 3:2 ratio but some shots are better 4:3 or square etc. Some end up as A4, whatever that ratio works out at. -- K e v i n --
Mcary Senior Member 978 posts Joined Oct 2006 Location: Virginia USA More info | Jul 09, 2007 13:09 | #3 I try to go with a 3:4 (9x12) as base ratio for a number of reason. Including that's the size of most models' books, plus cropping from 9x12 to 11x14 (size of my portfolio(s) and 8x10(16x20) seems to work very well. That being said if an image works best at 2.3 or 1:1 I simply print it with a border. OMG I saw a nipple, my eye's are bleeding!
| Latest registered member was a spammer, and banned as such! 2749 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
