Thread started 08 Jul 2007 (Sunday) 20:46
RAW + JPEG shows exposure difference - confused!
JeffreyG
Gallery: 42 photos
Jul 08, 2007 20:46 |  #1
I've shot RAW with my XT ever since I got it and I've handled the conversion with DPP (WB fix), RSE (batch) and Elements 5.0 (layers work, curves) according to my needs.
On a recent trip I figured I'd come home with 1000 shots and so I shot everything in RAW + JPEG to cut my post processing. I figured anything where I nailed the WB and exposure I would just use the JPEG's. My understanding is that the camera simply increases contrast, saturation and sharpening as you set it up when it saves the JPEGs.
So the weird thing was that on some of the shots, especially in bright sun, the JPEGs looked to be 1/2 to 1 stop more exposed than the RAW. There were some even where preserved hightlights in the RAW were gone an unrecoverable in the JPEG.
I opened everthing using Elements 5.0. What is going on here? Can the camera adjust the exposure when it saves the JPEG? Is Elements making some adjustments when opening the file? If so, how did Elements blow out highlights that exist in the RAW.
I'm confused. About the only thing I think I've learned is not to shoot in JPEG only mode.
Tel
Joined Jun 2005
Jul 08, 2007 21:15 |  #2
It may be that a contrast curve will make some of the mid-tones to highlights lighter. How do their histograms compare? I wouldn't expect there to be a difference where they start of finish.
Terry Cashman
30D - 300D - Sigma 17-70 f/2.8-4.5 - Sigma 70-200 f/2.8 - Canon 50 f/1.8
PacAce
Joined Feb 2003
Jul 08, 2007 21:23 |  #3
Your camera will process the JPG files the way you have your picture style parameters set. If the contrast is set too high, then it could very easily cause the highlight to get blown. The raw files, however, do not have the camera picture style parameters applied to them unless you are using DPP or Image/ZoomBrowser to process them with the default settings. Since you were using Elements, what you see in the raw preview will not necessarily look like the JPEG files coming out of the camera.
...Leo
davidcrebelxt
Jul 09, 2007 12:11 |  #4
You're seeing one of the benefits of shooting RAW... recoverable highlights... that you otherwise would assume to be gone forever with Jpeg since it throws information away when its processed.
(I still shoot RAW+jpeg myself, however, since jpeg is sometimes all I need.)
David C.
Equipment: Canon Dig. Rebel XT; 18-55mm EF-S; 28-105mm EF; 50mm 1.8 EF
Sigma ef-500 DG ST, Elements, Gimp, Lightroom
http://www.flickr.com/​photos/dcrebelxt (external link)
In2Photos
Jul 09, 2007 12:54 as a reply to  @ davidcrebelxt's post |  #5
By default ACR (the RAW engine in Elements) uses Auto settings which will "correct" the shot. You need to turn those off. You can do it manually for each shot by pressing CTRL + U or setup your default settings with this settings off.
Current Gear and Feedback
Curtis ­ N
Master Flasher
Jul 09, 2007 12:58 |  #6
JeffreyG wrote in post #3509821 (external link)
Autocorrect is probably the cause, as Mike says. Try opening both files in DPP and see what you get. Theoretically they should be the same.
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Jul 09, 2007 13:15 |  #7
The RAW shots will not have the parameter settings that the JPEG will have. Parameter 2 is neutral without any processing, parameter 1 has some saturation, contrast, and sharpness added for more pop though.
I'd doubt that this would lead to a 1/2 stop increase in exposure though. I suspect that you have the default auto exposure correction left on in PS. I hear you have to turn it off or it auto exposes everything as you upload.
Gallery: http://tomyi.smugmug.c​om/ (external link)
PacAce
Joined Feb 2003
Jul 09, 2007 18:24 |  #8
In2Photos wrote in post #3513161 (external link)
Curtis N wrote in post #3513183 (external link)
But the OP was complaining that the RAW images look good while the JPEG files shot at the same time looked overexposed. So he wanted to know why that is.
...Leo
In2Photos
Jul 09, 2007 21:24 |  #9
PacAce wrote in post #3514964 (external link)
Right, so the RAW is being corrected by ACR to be fixed which shows the difference. If he turns it off the difference might be gone. He didn't say that he wanted the shots to be correct, he asked why they would differ.
PacAce
Joined Feb 2003
Jul 09, 2007 21:37 |  #10
In2Photos wrote in post #3515771 (external link)
I guess the point I was getting at is that his out-of-the-camera JPEG files seemed to be overexposed. I can't think of anyway ACR would make a raw image look overexposed, if it wasn't that way in the first place, unless maybe if the Auto were turned on. Now, if we were talking about doing the conversion with DPP or Image/ZoomBrowser, then I might agree with your since those programs will, be default, process the image similarly to how the camera would.
...Leo
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Jul 09, 2007 21:48 as a reply to  @ In2Photos's post |  #11
My understanding of the auto correct function is that Adobe has created profiles for each model camera that ACR supports and the purpose of these profiles is to "normalize" the results for your camera model so that it will now emulate an ideal camera without inherent biases (please let me know if my understanding of this is incorrect). I don't believe that this is the same thing as the "Auto" function on the Basic tab of the ACR menu which adjusts Exposure, Recovery, Fill Light, Blacks, Brightness, and Contrast. So, which of these are we talking about?
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill (external link)
Donate to Support POTN Operating Costs
In2Photos
Jul 10, 2007 07:34 |  #12
PacAce wrote in post #3515844 (external link)
Didn't I say that the Auto settings would be on? :confused:
In2Photos
Jul 10, 2007 07:36 |  #13
bill boehme wrote in post #3515902 (external link)
I am talking about the checkboxes being turned on for the basic tab for the above in bold (although recovery and fill light might not be available on his version, not sure).
PacAce
Joined Feb 2003
Jul 10, 2007 13:42 |  #14
In2Photos wrote in post #3517746 (external link)
Yes you did but the OP said that the raw image was OK, not over-exposed like the JPEG. Maybe we're just going around in circles here. :lol: :)
...Leo
In2Photos
Jul 10, 2007 14:00 |  #15
PacAce wrote in post #3519639 (external link)
Maybe? Nope! We definitely are. :lol:
The Auto settings in ACR are designed to fix a photo whether it is underexposed or overexposed. So here is my thoughts written out a little more.
With the Auto settings ON the RAW file is fine. But, with the Auto settings OFF the RAW image would be overexposed just like the JPEG.
So now that we have figured out what caused the RAW file to appear different then the JPEG that question is answered. Now we can fix the shots, either with the Auto settings or each one manually.
Is that any better? Or are we still circling? :lol:
2,838 views & 0 likes for this thread, 10 members have posted to it.
2876 guests, 135 members online
