I've been reading through the stickies (Curtis is awesome), but I'm still not sure of the answer to my particular question.
With the original 580 speedlite (not the newer II) and the 30 D, will the camera automatically know you're after a fill flash, OR, must one dial in the -1 FEC setting to achieve fill flash??
I know I must be missing something from my readings, but for the life of me, I can't seem to grasp this. I've done alittle flash with manual exposure, and I understand that the background is controlled by the aperture-shutter combination you select from the manual controls, and the foreground is controlled by the flash. What I can't understand is whether or not the camera knows you want fill-flash to begin with, or if you must dial in the -1 setting on FEC.
Another related question: to fool the camera into thinking you want fill-flash, should the background (manipulated by the manual controls) be metered to the right of center (slightly over), or to the left of center (slightly under), to achieve fill-flash automatically without setting FEC??
Last question - when you want a shallow DOF with blurred background and achieve that in manual setting, will using a flash override that and give you a deeper depth of field then you wanted?
Thanks!!!
The decision is yours, based on how much control you want, how much time you have, and what you're comfortable with. Keep in mind that Manual mode is often recommended for
