Thread started 10 Jul 2007 (Tuesday) 08:32
Accidental Flash
Maxdave
Gallery: 49 photos
Jul 10, 2007 08:32 |  #1
First I use a 580EX on a XTi with a battery grip attached.
I have been noticing that often my flash fires at seemingly random times (often when I am carrying it at my side). One pro told me it was my FEL being fired accidently by the way I held the camera and grip (he thought my thumb was triggering the "*" button on the grip accidently). Since he mentioned this, I try to make sure I touch neither of the "*" buttons (on the grip or the camera itself), but I still seem to get accidental flashes going off.
Is there some other way this could be happening I have missed? Is there some change in settings I could make to futher isolate the cause, and then eliminate it?
Thanks in advance to anyone who can figure this one out or has had it happen to them also (I used the same flash, battery grip setup with my 300D and never ran into this ...).
Maxdave
5D3,1D4,S90,6S&Moment Lenses,Hero4Silver,GPS​-E2,2x580EX,430EX,90EX,​EF16-35L f/4 IS,Samy SYTS24-C 24TS,EF24-105L IS,EF50 f/1.4,EF70-200 f/4L IS,EF300 f/4L IS,EF100-400L I IS,Kenko DGX 1.4X,Canon 2X TC Mk II, RRS&Pro-Media L-Brackets,Manfrotto MHXPRO-3WG & Roller 50,Sirui 306&K-20,Giottos MT-7371&MH-3300,Velbon ElCarmagne 530,CamRanger,Phottix&​Canon Remotes,Lowepro Backpack,ThinkTank Retro 20&Modular System,OpTech straps,Lexar/San Disk Cards
Curtis ­ N
Master Flasher
Jul 10, 2007 09:02 |  #2
Change custom function 4 on the XTi to 1 and see if the problem persists.
Note - This makes the * button your autofocus button. It takes some acclimation but gives you greater control over the autofocus process.
Also make sure you aren't hitting the DOF preview button (which activates the modeling light), or disable the modeling light via custom function on the 580EX.
kcds
Nov 19, 2007 05:42 |  #3
Maxdave - I am seeing the same behavior with a 430EX on my XTi (w/o battery grip). In my case, the "random' flashes seem to come in groups of 3, but otherwise do indeed seem random, with perhaps some correlation to jiggling or shaking the camera (!) You still seeing the behavior?
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Nov 19, 2007 10:07 |  #4
Maybe static electricity.
kcds
Nov 19, 2007 10:50 as a reply to  @ PhotosGuy's post |  #5
Heh - after watching my hands a little more closely, I think i am hitting the "*" key after all, and that's causing the FEL flash to fire. Oops. Good call!
Maxdave
Gallery: 49 photos
Dec 04, 2007 23:09 as a reply to  @ kcds's post |  #6
I agree with you ... I have since got a 40D with the battery grip, and it never happens with it.
2,566 views & 0 likes for this thread, 4 members have posted to it.
Accidental Flash
1040 guests, 105 members online
