I have a picture with a lot of trees and would like to remove the sky behind it.
What is the easiest way to remove all the sky in the nooks and crannies? is there a technique anyone can recommend?
much thanks
azpix Goldmember 3,335 posts Likes: 19 Joined Oct 2006 Location: Chandler, Arizona USA More info | Jul 10, 2007 23:53 | #1 I have a picture with a lot of trees and would like to remove the sky behind it. Gear- 7d, 24-70L, sigma 70-200, Sigma 120-400, canon 50 1.4, Canon 100 2.0,sigma 10-20 and a DJI Mavic Pro Drone
BillBoehme Enjoy being spanked More info | Jul 11, 2007 00:25 | #2 Ther are probably better and faster ways, but I often use the Magic Wand tool. It can be tedious and time consuming if done carefully. If not done carefully, the results can be crummy looking with lots of jaggies. Also the Magic Eraser tool works well. I am sure that there are much more clever ways available now in PS that were not there years ago when I learned to do these things on early versions of PS. Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Titus213 Cream of the Crop More info | Jul 11, 2007 00:32 | #3 Have you seen this? http://av.adobe.com …brown/AdvancedMasking.mov Dave
ssim POTN Landscape & Cityscape Photographer 2005 10,884 posts Likes: 6 Joined Apr 2003 Location: southern Alberta, Canada More info | That is one of the hardest things to do and make it still look good. It can be done but be prepared for lots of tweaking on your selection. My life is like one big RAW file....way too much post processing needed.
BillBoehme Enjoy being spanked More info | You can also sometimes use the cloning tool to fill in some of the sky "holes" in trees with leaves as long as you don't go overboard and turn the tree top into a round green ball. Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
PhotosGuy Cream of the Crop, R.I.P. More info | Jul 11, 2007 07:39 | #6 Do you need to remove it, or just darken it? Some good links in here: FrankC - 20D, RAW, Manual everything...
| Latest registered member was a spammer, and banned as such! 2742 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
