Thread started 11 Jul 2007 (Wednesday) 09:25
white balance eyedropper, ACR4.1
chauncey
Jul 11, 2007 09:25 |  #1
I use this method.
Search the image at 200% for a gray spot with RGB readings very close to 120 +5/-5 and click my eyedropper on that area. I then preform my adjustments in "fit to screen" mode until I'm satisfied with the image. Then as a final tweek, I repeat step one.
From a technical aspect, is there a problem with my method?
tim
Light Bringer
Jul 11, 2007 18:41 |  #2
Sounds ok, but very slow. I use presets then tweak them a bit sometimes.
peatoire
Joined Nov 2005
Jul 12, 2007 10:09 |  #3
Maybe I'm misreading you chauncey but if the file is RAW then a gray spot could be any number of colours depending on your white balance setting.
The method I tend to use is to click on something you know is white or gray and use that to set your white balance, you can then use those settings for other shots albeit the lighting conditions are the same.
I also have a gray card which works well.
5D & Grip, 17-40 f4, 70-200 f2.8 IS, 50mm 1.4, 85mm1.2 580EX 430EX II, Tamron SP AF 90mm f/2.8 Macro. Rickety tripod.
Andy Peat
Don't underestimate the power of stupid people in large numbers.
chauncey
Jul 12, 2007 11:23 as a reply to  @ peatoire's post |  #4
thanks guys, I appreciate the input
1,179 views & 0 likes for this thread, 3 members have posted to it.
2889 guests, 134 members online
