I just bought a Sumpak 5000AF flash for my Canon 10D and I can figure this thing out. I'm not even sure if this flash is totally compatible with my Canon 10D... Did I make a mistake and I should add an other $100 bucks and get a Canon 550?
saikidesign Junior Member 28 posts Joined May 2004 More info | Jun 12, 2004 10:08 | #1 I just bought a Sumpak 5000AF flash for my Canon 10D and I can figure this thing out. I'm not even sure if this flash is totally compatible with my Canon 10D... Did I make a mistake and I should add an other $100 bucks and get a Canon 550?
Canuck Goldmember 1,592 posts Joined May 2003 More info | Jun 12, 2004 19:16 | #2 saikidesign wrote: I just bought a Sumpak 5000AF flash for my Canon 10D and I can figure this thing out. I'm not even sure if this flash is totally compatible with my Canon 10D... Did I make a mistake and I should add an other $100 bucks and get a Canon 550? ![]() I have an ancient (about 1987) Sunpak auto 36DX thyristor that works perfectly w/ the 10D. So long as it is TTL you should be ok. I haven't tried it on the EOS 50E, but don't see why it shouldn't work, after all the 10D is at least 3 years newer!
Jun 13, 2004 09:12 | #3 Hi Canuck, Thanks for your reply. Acually I solved my problem sending back my Sunpak and I just bought a Canon 550EX. The difference is huge and everything is syncronized and work simply well. After all, Sunpak works, but there are some inportant features like flash compensation that does not work with my 10D and it never worked on "P" mode. Canon 550EC is more money but I get a lot more performance ot of it. Regards, Oswaldo.
Canuck Goldmember 1,592 posts Joined May 2003 More info | Jun 13, 2004 09:22 | #4 saikidesign wrote: Hi Canuck, Thanks for your reply. Acually I solved my problem sending back my Sunpak and I just bought a Canon 550EX. The difference is huge and everything is syncronized and work simply well. After all, Sunpak works, but there are some inportant features like flash compensation that does not work with my 10D and it never worked on "P" mode. Canon 550EC is more money but I get a lot more performance ot of it. Regards, Oswaldo. Cool, glad u got it sorted. I had forgoteen about FEC, and other cool buts. I wasn't sure if you were leaning toward keeping the SunPak or not. I guess it proves again, when in doubt, buy Canon.
| Latest registered member is AlainPre 1779 guests, 156 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
