Thread started 13 Jul 2007 (Friday) 10:27
What are your LR import prefs and why?
cosworth
I'm comfortable with my masculinity
Jul 13, 2007 10:27 |  #1
I've tried a couple runs importing files and trying to integrate with my pre LR archive.
What import options did you find useful to making a seamless archive?
people will always try to stop you doing the right thing if it is unconventional
Full frame and some primes.
In2Photos
Jul 13, 2007 10:35 |  #2
First let me say that I wish you could have favorite Import prefs like you do Export prefs. :evil:
Now, here is what my typical import prefs look like.
I copy and convert to DNG from CF card to HD to a folder titled To Be Sorted, by date (2007/July 13 for example).
I backup to a folder titled Needing Backup. This creates a folder for each import with the original filename from the camera and does not convert to DNG.
My filename pref is 2007_07_13__MG_8239.DN​G so date_original filename.
I use a preset called Import Starting Point. I created this preset to zero out the sharpening from LR 1.0. I still use it even though 1.1's sharpening is improved because I haven't found that setting I want to use yet. Otherwise everything else is as shot.
I use my Copyright for the metadata template.
I add keywords.
I do not render previews.
Current Gear and Feedback
cosworth
Jul 13, 2007 10:41 |  #3
I'm so with you on the export bit. But wow, I like your ideas for import. Mine seem savage and archaic compared to what you're doing.
I'm flipping, I'm going to try a similar if not exact setup as you and back-modify my catalogue to match the new workflow. My old and current camera calibration plus zero'd sharpening will be my preset for sure. I'll back up before of course. I see a terabyte in my future.
Thanks a ton!
871 views & 0 likes for this thread, 2 members have posted to it.
2889 guests, 134 members online
