But I don't know what to search for. My question is:
What are the different sizes that you can print without having to crop the picture on a 1.6x crop body?
Thanks in advance!
350D_Noob Senior Member 877 posts Joined Jan 2006 Location: Virginia Beach, Va. More info | Jul 14, 2007 17:16 | #1 But I don't know what to search for. My question is: Gear List
scot079 Goldmember 3,839 posts Likes: 1 Joined May 2007 Location: Maryland USA More info | Jul 14, 2007 17:18 | #2 if you have photoshop, use the crop tool and crop to 8x10 and then your pic won't be resized or manipulated by printing software. - Tim
Jul 14, 2007 17:48 | #3 True, but most of my pictures are composed to fit almost the whole frame. Gear List
scot079 Goldmember 3,839 posts Likes: 1 Joined May 2007 Location: Maryland USA More info | Jul 14, 2007 17:51 | #4 i'm sorry i don't know what you mean. - Tim
Jul 14, 2007 18:21 | #5 Most of the time when I take pictures. The subject can fit almost the whole frame. Which means I really won't have much to crop. Hope that helps. Gear List
scot079 Goldmember 3,839 posts Likes: 1 Joined May 2007 Location: Maryland USA More info | Jul 14, 2007 18:23 | #6 got it, then why did you make the post? - Tim
ssim POTN Landscape & Cityscape Photographer 2005 10,884 posts Likes: 6 Joined Apr 2003 Location: southern Alberta, Canada More info | Jul 14, 2007 18:26 | #7 350D_Noob wrote in post #3544893 True, but most of my pictures are composed to fit almost the whole frame. ![]() You really to think ahead to what you will be doing with an image if possible. It is not possible to print all sizes without losing a part of the image. I always leave enough room around the primary subject in the image so that if I want to print an 8x10 I can do that while still maintaining all of the primary subject. My life is like one big RAW file....way too much post processing needed.
Jul 14, 2007 18:31 | #8 ssim wrote in post #3545054 You really to think ahead to what you will be doing with an image if possible. It is not possible to print all sizes without losing a part of the image. I always leave enough room around the primary subject in the image so that if I want to print an 8x10 I can do that while still maintaining all of the primary subject. For example, using a 30D image that I have you get to print it all on a 4X6, the 5x7 you lose a little and the 8X10 and 11X14 you lose a fair bit. If you are going to fill up your frame with the subject and want to print 8X10 then you need to be prepared to lose that portion off of one end, or both ends as the case may be. My 30D image was shot in RAW and processed from C1 Pro at 300DPI and it is 3504X2232 px which is 11.7X7.8 inches. If you want to keep the full frame you have to work to those proportions. Noted, but I'm still curious as to what sizes I can get without having the image crop. Gear List
partsman Member 210 posts Joined Jan 2006 Location: St. Louis, MO USA More info | I believe your camera has a sensor with a 2x3 aspect ratio so you can print any variation of 2x3, such as 4x6,6x9,8x12, etc. without having to crop. Mark
Jul 14, 2007 18:34 | #10 partsman wrote in post #3545077 I believe your camera has a sensor with a 2x3 aspect ratio so you can print any variation of 2x3, such as 4x6,6x9,8x12, etc. without having to crop. Thanks! That's all I was looking for. Gear List
| Latest registered member was a spammer, and banned as such! 2915 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
