http://ds.dial.pipex.com …Shell/DownloadRequest.htm![]()
Freeware, programmed by David Stout.
Please mail comments to photographer@dial.pipex.com![]()
Pekka El General Moderator More info | May 31, 2001 02:00 | #1 http://ds.dial.pipex.com …Shell/DownloadRequest.htm The Forum Boss, El General Moderator
LeoR Mostly Lurking 17 posts Joined Apr 2001 More info | May 31, 2001 19:35 | #2 I downloaded Yarkshell but have not installed it yet. Perhaps I missed a discussion on this. Could you tell me the difference between this and Yarc?
rknol Junior Member 27 posts Joined Apr 2001 More info | May 31, 2001 23:28 | #3 Yarcshell is a grafical shell around Yarc. To use Yarc you have to enter the options on the commandline. If you use Yarcshell, you have to choose your options with checkboxes and option buttons. Yarcshell manages Yarc.
LeoR Mostly Lurking 17 posts Joined Apr 2001 More info | Jun 01, 2001 06:18 | #4 Thanks, I will give it a try.
LaptopPop Member 32 posts Joined May 2001 More info | Jun 02, 2001 13:20 | #5 I just tried it out - seems to work very well! I'm still working out my workflow with this beast. Seems like I come back from a typical event with a few hundred shots, and I'm not having much luck with keeping it all organized yet. On the other hand, I like how the YARC/YARCShell combination lets me work with the RAW format - gives me a lot more flexibility for later.
F.HA Hatchling 1 post Joined Jun 2001 More info | Jun 07, 2001 10:48 | #6 Tried to download.... but the link does not work any longer....
duncanc Member 78 posts Joined Aug 2001 Location: Catalonia More info | Aug 28, 2001 08:11 | #7 The correct URL is: Duncan C
| Latest registered member is vinceisvisual 1230 guests, 178 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
