Thread started 17 Jul 2007 (Tuesday) 05:38
Q re: Gitzo CF tripods with rapid column
Rudi
Joined Mar 2002
Jul 17, 2007 05:38 |  #1
Hi everyone,
Recently I acquired the new Gitzo GT2530. This is my first Gitzo tripod, and I am very impressed with the sturdiness of the tripod so far. Compared to my aluminium Manfrotto tripod, it transmits next to no vibration, it is lighter and sturdier, especially when both are fully extended.
There is one thing though, that bugs me a little bit. It is not something that I will lose too much sleep over, but it seems like a little imperfection in the Gitzo design. With the centre column, if you grab it and twist it from side to side, there is always a little play, no matter how much you tighten it! When you look at the centre column, it is round, with a little groove in the side. Into this groove fits a protruding tongue, which effectively locks the column so that it cannot rotate, but because of the tolerances involved, there is always a little play in the system.
My Manfrotto centre column is triangular and so is the opening in the tripod spider, and because of that it cannot rotate at all. In fact, trying the two tripods side-by-side, the Manfrotto is clearly the winner in that department (and only that department). As soon as you extend the legs, the Gitzo pulls ahead and there is no competition. But... it seems like a weakness in the design.
I have seen a similar thing on a friend's Gitzo, but did not think about it at the time, since I wasn't in the market for one at that time. Typical!
Is your rapid column Gitzo the same? Is there anything that can be done about it, or is it just art of the design? I can take the centre column out altogether, if I want a sturdier (and lighter) setup, so it won't be a problem in general use, it is just a little surprising, that's all. Please note that this is not Gitzo-bashing or anything like that, I am just haring an observation.
So, all you Gitzo owners, what's the story ???
• Wedding Photographer - Sydney and Wollongong (external link)
• Borrowed Moment (blog) (external link)
Life is uncertain. Eat dessert first.
Rudi
Joined Mar 2002
Jul 17, 2007 07:41 |  #2
I should mention that this is not complete freeplay, it's damped by the fact that the centre column is tightened, kinda like a shock absorber, but it is there.
Anyone?
PacAce
Joined Feb 2003
Jul 17, 2007 08:38 |  #3
That may explain why the majority of the Gitzo users (from what I've seen) do not use the center column. I don't either. Even on my Manfrotto which has a center column, it's never lifted up because lifting it just makes the platform that the camera is resting on less stable. If I could just use the top part of that column (to mount the head on) and remove the column itself, I would.
...Leo
Quad
Joined Nov 2005
Jul 17, 2007 08:48 |  #4
Gt2540 here no play extended or down with just a bit of tightening. I could tighten more but enough is enough. Must be the fourth leg I have. :)
Rudi
Joined Mar 2002
Jul 17, 2007 09:10 |  #5
How much freeplay (twisting the column around its long axis) do you guys have when loosened? How about when tightened??? That's what happens - even when I tighten it, the freeplay is still there - damped out a little, but I can still twist it!
I need to find out soon, in case I have to send it back to B&H for a replacement.
Rudi
Joined Mar 2002
Jul 18, 2007 21:22 |  #6
It's going back! See how much play there was:
http://www.youtube.com​/watch?v=gl4aZIKNqUk (external link)
SunTsu
Jul 21, 2007 02:50 |  #7
Good video. I don't have a center column, but that amount of play seems a bit much. Please do let us know what your replacement is like.
I bought a 3530S from RRS and there was a ding in it. It doesn't affect the performance, but for $600, it kind of bugs me. Point is, I guess no matter what you spend, things just don't seem to be as good as you'd think.
Canon 5D Mark II+BG-E6, Canon 5D+BG-E4 | 200-400mmL IS, 85mm F1.2L II, TS-E 17mm F4.0L , 16-35mm F2.8L II, 24-105mmL IS, 70-200mm [COLOR=#000000]F2.8L II IS, 100mm F2.8L Macro IS, 100mm F2.8 Macro, 40mm F2.8, 1.4x II, 2.0x III | EF12+25 II | Canon 600EX-RT (x5) | Gitzo support
Full Gear List
freaking102
Jul 21, 2007 10:22 |  #8
no play in mine. very solid when raised.
Rudi
Joined Mar 2002
Aug 10, 2007 02:10 |  #9
Just a follow-up:
I have since received a replacement from B&H, and it is rock solid. Customer service from both B&H and Gitzo has been exemplary, they both went out of their way to help. Gitzo even emailed me after seeing the video on YouTube, to double-check that my concerns have been addressed and that I am happy with the product. Top-notch!
foxbat
Joined Jan 2005
Aug 10, 2007 03:41 |  #10
Rudi wrote in post #3701245 (external link)
Just a follow-up:
That's what I call service. Good to see that you're happy.
Andy Brown; South-east England. Canon, Sigma, Leica, Zeiss all on Canon DSLRs. My hacking blog (external link).
2,791 views & 0 likes for this thread, 6 members have posted to it.
1589 guests, 139 members online
