Thread started 18 Jul 2007 (Wednesday) 01:57
EOS UTILITY
MKII
Jul 18, 2007 01:57 |  #1
hi guys...i have my eos utility installed in my pc but i cannot upgraded with the last version.....it says ''can not install eos utility in this computer...''
whats going on.....? ??
ps..DPP has been upgraded succesfully.....
Facebook Page: http://www.facebook.co​m/JohnDomPhotography (external link)
http://JohnDomPhoto.Co​m (external link) - http://JohnDomWeddings​.Com (external link)
lkb-28
Jul 18, 2007 02:36 |  #2
Hi John;
Are you running an older (un-supported) opsys?
Did you verify the system requirements for the upgrade?
Lee
Comments & Criticisms ALWAYS welcome...:D
Still a rank amateur - but learning day by day...:D
Equipment
MKII
Jul 18, 2007 04:43 |  #3
yes...i run windows xp 's....i dont know whats going on....
ps..same thing for eos capture software...it just cant be installed....
PaulB
Joined Apr 2003
Jul 18, 2007 04:53 as a reply to  @ MKII's post |  #4
Sounds as if the original installer has been corrupted, deleted or had a registry entry changed/deleted.
The simple way round this is to uninstall all the Canon software, reinstall from the original disks and then update everything.
If the software won't uninstall then you need to clear the Canon installers from your system - go the the Microsoft website and look for, and download the Windows Installer Cleanup Utility. When you run this look for the Canon software in the list and clear the installers for this. Then reinstall from your original disks and update after that.
If that doesn't work then you need to create some registry keys which will allow the updates to install but I'd hesitate to point you in that direction as messing with the registry can seriously damage WinXP; to the point of making it unbootable............​..
Anke
Jul 18, 2007 04:54 |  #5
Are you trying to jump from one version over another, i.e. version 1.0 to 1.2 bypassing 1.1
As far as I can remember when I used to use DPP this always caused a problem and I had to upgrade through the series logically. And some versions of the software require other versions i.e. you must update DPP before updating EOS Utility.
Hope this helps
Anke
MKII
Jul 18, 2007 05:55 |  #6
I did update dpp first anke....but....nothing​.....i dont think though that it needs to go from 1 to 2 and then to 3 for example...as the version 3 includes no 1 & 2...i think that paul is correct...i ll try that....and ill see...
lkb-28
Jul 18, 2007 05:58 |  #7
Hi John;
Before you start messing with uninstall & the registry... I suggest you check any firewalls first.
It won't be the first time that my firewall has prevented an update without "allowing" it within the firewall parameters...
Good luck;
Cheers;
Lee
Equipment
MKII
Jul 18, 2007 06:05 |  #8
thanks my friend lee...but i dont think that is the firewalls...dpp and zoombrowser have been installed succesfully....the other 2 (eos utility and eos capture) just refuse to be installed.....i think its what paul said....
Hermeto
Jul 18, 2007 06:20 |  #9
Uninstall, reinstall original version that came on CD, update to the newer, downloaded version.
If that doesn’t work, cleaning the Registry as suggested above, definitely will.
3,270 views & 0 likes for this thread, 5 members have posted to it.
EOS UTILITY
2862 guests, 140 members online
