Thread started 18 Jul 2007 (Wednesday) 08:15
Why "only" shoot RAW ?
lkb-28
Jul 18, 2007 08:15 |  #1
Hi Guys;
I've seen a great many comments on the forum about taking the "big-step" and ONLY shooting RAW...
What is the perceived advantage in doing so - apart from maybe saving a relatively small amount of storage space?
Seems to me that the "sensible" thing to do is to shoot RAW+JPEG !
Grateful for the insight that I'm clearly missing here!
Cheers;
Lee
Comments & Criticisms ALWAYS welcome...:D
Still a rank amateur - but learning day by day...:D
Equipment
Stavhp
Jul 18, 2007 08:24 |  #2
why shot Raw+jpeg
the RAW file itself gives you much more quality in the final result and gives you more room for eposure and WB adjustments and if you really want a JPEG you can just edit hte RAW into a jpeg
Long live RAW :)
Canon 7D, sigma 17-70, Canon 50mm F1.8, Canon 70-300mm IS
http://www.flickr.com/​photos/stav-p/ (external link)
Curtis ­ N
Master Flasher
Jul 18, 2007 08:33 |  #3
The JPEG file is an unnecessary redundancy. It's like towing an old beater behind your new Cadillac.
The only time I use JPEG is in those rare instances when I have absolutely zero time for processing or no access to the necessary software.
lkb-28
Jul 18, 2007 08:36 |  #4
Hi Stavhp;
Stavhp wrote in post #3565815 (external link)
why shot Raw+jpeg
...So I can review the image in-camera instantly and at any time thereafter!
I'm not questioning the massive advantages of RAW; I'm sold on that; only the "reasons" why you wouldn't shoot RAW AND JPEG !
Cheers;
Lee
Equipment
bcap
MR. PP
Jul 18, 2007 08:37 |  #5
When you shoot RAW, you can still see the photo in-camera afterwards ...
Bryan
Bryan Caporicci's Personal Blog (external link)
Niagara Falls, Ontario Wedding and Portrait Photographer - Bryan Caporicci Photography (external link)
timbernet
send a search party to Mount Hood
Jul 18, 2007 08:44 |  #6
lkb-28 wrote in post #3565878 (external link)
Hi Stavhp;
Cheers;
Lee
I can review the image afterwards with RAW no problem... The reason I shoot "only" RAW is because of CF card space... I get a lot more shots to a card by not shooting RAW+JPEG.
Curtis ­ N
Master Flasher
Jul 18, 2007 08:44 |  #7
Yeah, that's pretty much the way it works with RAW, too. :D
Even if you shoot RAW only, the RAW file contains an embedded JPEG that's used for the camera display as well as thumbnail images with your RAW conversion software.
sando
Jul 18, 2007 08:48 |  #8
Because using RAW+JPEG is a waste of memory.
I cold see the advantage of shooting RAW+smallJPEG - but I still think the 'small' JPEG is too large. I'd like to see a RAW+640pxJPEG option.
- Matt
lkb-28
Jul 18, 2007 08:49 |  #9
Hi Guys;
Well - you learn something everyday...
bcap wrote in post #3565883 (external link)
Curtis N wrote in post #3565919 (external link)
Lo & behold, I've just tried, and it works!
I guess when I had previously read about viewing the "embedded JPEG" in-camera, my tiny little brain then said "..well; that means you can't view the RAW file..."
So, now I don't need all four 4Gb cards I have...
Anybody wanna buy one?
Thanks & cheers;
Lee
Equipment
cfcRebel
Jul 18, 2007 08:59 |  #10
lkb-28 wrote in post #3565937 (external link)
Thanks & cheers;
Lee
You still need them once in while, especially when you go on a family trip, or party, and take thousands of photos. Friendsly and relatives want the photo immediately. That's when the jpegs come in handy. ;)
Fee
Canon | SIGMA | TAMRON | Kenko | Amvona
lkb-28
Jul 18, 2007 09:11 |  #11
Hi cfcRebel;
cfcRebel wrote in post #3565978 (external link)
Yep; I don't plan to abandon RAW + JPEG...
I have the space; storage is now cheap - and getting cheaper by the day - so I'm quite happy with the "redundancy" of both JPEG and RAW...
Cheers;
Lee
Equipment
GeoffSobering
Jul 18, 2007 09:25 as a reply to  @ lkb-28's post |  #12
The only reason I don't shoot Raw+Jpeg is that it slows the buffer clearing time a bit. I mostly shoot bursts of 3+ frames, so I regularly fill the buffer. It's also nice to get a few extra frames per card (I also burn through memory at a pretty good clip...).
When I'm shooting more static things, I tend to shoot Raw+Jpeg.
Cheers,
Geoff S.
http://moving-target-photos.com/ (external link) - My Stuff
prime80
Jul 18, 2007 09:41 |  #13
I don't shoot RAW+jpeg because it's just an extra file I'm going to have to deal with. I know I'm going to end up using the RAW file for anything I do with the image, so why have the redundant jpeg as well? It's just going to get trashed. At the end of a shoot I'd much rather have to deal with 300 pictures than with 600 pictures. IMO, RAW+jpeg is great for if you're just starting out with RAW, so you have the jpeg "safety blanket", but once you get a good RAW workflow down, I see no reason for the extra jpeg. Obviously there are exceptions to that where you need a jpeg for quick printing, proofing, etc., but in general I just see it as a wasted file.
John
R6, EF 100-400 L IS II, EF 24-70 L II, EF 85 f/1.8
Full Gear List
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jul 18, 2007 10:19 |  #14
lkb-28 wrote in post #3565781 (external link)
Well, relative, is relative,.
If I shoot 18 GB of RAW files,. and also shoot jpeg, thats another 5GB of space taken up by jpeg files that I will never use.
Of course if you are going to use the jpegs, then by all means shoot both. But if you won't, then what's the point?
A much bigger concern is the in camera processing time needed when shooting high speed.
CDS' HOT LINKS
Hangerhead
Jul 18, 2007 10:43 |  #15
do people automatically assume that al their shots are going to require some extensive amounts of post-processing?
If you get it right 'in camera', then possibly apart from some minor levels, there's no benefit in RAW is there?
www.hangerhead.smugmug​.com (external link)
Canon 1DS MK II, Canon 40D
Canon 70-200mm L f4, Canon 50mm f1.4, Canon 17-55mm IS f2.8, Canon 85mm f1.8, Canon 24-105 IS f4 L, 17-40 L
3,238 views & 0 likes for this thread, 22 members have posted to it.
2867 guests, 140 members online
