I haven't used the burst mode much with flash.
Canon d10 with 550EX.
Is there any problem shooting 8 bursts consecutively at raw or Max Jpeg?
Anything I should consider?
Thanks.
johnanthony Hatchling 2 posts Joined May 2004 More info | Jun 15, 2004 21:10 | #1 I haven't used the burst mode much with flash.
timmyquest Goldmember 4,172 posts Joined Dec 2003 Location: Outside of Chicago More info | Jun 15, 2004 21:12 | #2 Permanent bani Use to wonder the same thing, in most situations the flash has no problems keeping up with the camera. If you are stopped all the way down in a dark room at ISO 100 then yes...but typically no you wont have an issue. Capturing life a fraction of a second at a time
Jim_T Goldmember 3,312 posts Likes: 115 Joined Nov 2003 Location: Woodlands, MB, Canada More info | Jun 15, 2004 21:52 | #3 I just tried it with my 10D/420EX.. Night time in a room brightly lit with incandecent lamps.
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | Jun 16, 2004 00:37 | #4 If you had perfect AA batteries inside the 550EX, then it might be able to perfectly keep up with the camera. However, AA batteries that are perfect are hard to find. A compact flash battery will supplement the current available for the flash tube, but that is another thing to buy.
| Latest registered member was a spammer, and banned as such! 2467 guests, 106 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
