Thread started 18 Jul 2007 (Wednesday) 15:54
shoot raw indoors
mrkeenan0
Jul 18, 2007 15:54 |  #1
Can I shoot RAW indoors in low light (i.e. a basketball gym) and underexpose to get a higher shutter speed to freeze the action and then adjust it later without losing the details?
i.e. can i shoot at -1 stop to use a shutter speed of 1/500 rather than 1/250 and then adjust the picture before i convert it so its properly exposed or am i better off shooting the right exposure the first time even if its a bit slower shutter speed?
Thanks!
Rebel XT - 24-70 2.8 L - 70-200 2.8L IS - 28-200 3.5-5.6 - 50 1.8
Pete
Jul 18, 2007 16:01 |  #2
Shooting in RAW isn't a miracle cure for getting around difficulties in exposure.
Your best option would be to increase your ISO. That will allow you the exposure leeway you need.
Pete
UK SE Catch of the Day
Anh ­ Nguyen
Jul 18, 2007 16:07 |  #3
raise ISO or get a lens with a wider aperture.
Anh Nguyen (external link)
70-200 2.8, 580EX II, 50 1.8, 17-50 2.8
nwa2
Jul 18, 2007 16:11 |  #4
If you want to freeze motion you need to think about shutter speed first.
e.g. You decide 1/250 is fast enough to freeze the action -
You - select shutter priority and 1/1250
camera - will select an apperture to give you correct exposure
You - need to assess aperture selected - will it give you the right DoF
If not there are various options - dial in compensation; use flash; change shutter speed; you can also pan the camera to reduce your minimum shutter speed.
In all cases shooting in RAW will give the best oportunity to adjust exposure in PP by +/- one or two stops.
The downside is that RAW is more demanding writting to the CF card so it will fill your buffer faster.
Canon 6D; 7D; 40D:
There are many tomorrows', but only one today!!
[SIZE=1][COLOR=Black]http://www.Abercrombie​.me.Uk (external link)
http://imagesix.wordpr​ess.com/ (external link)
TeeJay
Joined Jun 2005
Jul 18, 2007 16:15 |  #5
If you are shooting in bad light and increasing your ISO (even in RAW) you'll get noise if you then try and adjust it by much.
In these conditions you really need your exposure as close as possible.
TJ
1DsMkIII | 1DMkIIN | 70-200 f/2.8L IS | 24-70 f/2.8L | 24-105 f/4L IS | 17-40 f/4L | 50 f/1.2L | WFT-E1 & E2 Transmitters - Click Here for setup advice | CP-E4 Battery Pack x 2 | ST-E2 | 580EX | 550EX | 430EXII | 420EX | Tripod + monopod | Bowens Esprit Gemini 500W/s heads & Travel-Pak | All this gear - and still no idea :confused:
mabas9395
Jul 18, 2007 16:28 as a reply to  @ TeeJay's post |  #6
My 10yo son plays indoor soccer and even with my XT at ISO 1600 and my 85mm f/1.8 wide open at f/1.8, I find that I still can't get fast enough shutter speeds. I could get an even faster lens or a body that can shoot higher than 1600 ISO. But I've found that the most practical solution is to do what you said, underexpose 1 stop in RAW and increase the exposure in post. But that would be a last resort only after I've maxed out my ISO and aperture.
The downside is the results are extremely noisy and with an extremely narrow DOF. The first isn't that much of a problem because I'd rather have a noisy shot than one with motion blurr. But the narrow DOF makes it even harder to get the focus accurate, but when you can, the results are the best you can get in difficult lighting.
"You only get one sunrise and one sunset a day and you only get so many days on the planet. A good photographer does the math and doesn't waste either." - Galen Rowell
942 views & 0 likes for this thread, 6 members have posted to it.
shoot raw indoors
2862 guests, 140 members online
