Is there a correct way to adjust the levels and curves or do you do it until you like the results? I know each pic is different but im not to sure how they both work.
TeriD Member 230 posts Joined May 2007 Location: Santa Clarita, Ca More info | Jul 19, 2007 23:16 | #1 Is there a correct way to adjust the levels and curves or do you do it until you like the results? I know each pic is different but im not to sure how they both work.
Stavhp Goldmember 2,303 posts Joined May 2006 Location: UK More info | Jul 19, 2007 23:17 | #2 do it until you like what you see Canon 7D, sigma 17-70, Canon 50mm F1.8, Canon 70-300mm IS
joayne Cream of the Crop More info | Jul 19, 2007 23:26 | #3 Curves are said to be a more delicate approach to adjustments, while levels is a bit less delicate. Rather similar approaches, one being gentle and the other a bit of a bash. Curves is more advanced and you should take some time to learn some technique as I believe it is less *invasive* to your image. You can *test* areas of an image and see them in the curves interface so you know where to adjust... there is a learning curve. joayne Contribute to POTN | Worldwide Photo Week
Damo77 Goldmember 4,700 posts Likes: 115 Joined Apr 2007 Location: Brisbane, Australia More info | Jul 19, 2007 23:33 | #4 Until you really know the answer to your own question, I'd recommend principally using Levels.
Jul 20, 2007 00:35 | #5 Thanks. I have tried to learn how to read the histogram but it's so confusing to me. I also read something about levels but im still not sure if im adjusting it right.
vetkrazy Goldmember 1,019 posts Joined May 2006 Location: Just North of South, next to the Joshua tree More info | Jul 20, 2007 00:49 | #6 Hey TeriD, nice to see another local. If you are interested PM me and we could get together and I could maybe give you a few pointers. Wrap your ass in fiberglass.... You're only young once but you can be immature the rest of your life
Jul 20, 2007 01:36 | #7 Hey Bruce, Didn't know anyone here was from this area. Good to see a neighbor. Is that your vet in your avatar? It looks familuar. Are you located on the east or west side? I could defintly use some pointers, this photography is harder than it looks so I just might take you up on it.
IainB Goldmember 1,427 posts Likes: 2 Joined Jan 2002 Location: Auckland, New Zealand, More info | Jul 20, 2007 02:17 | #8 A tip about using Curves or levels is to use them via an adjustment layer to erase/fine tune parts of the image later. Adjustment layers don't iincrease the file size. _______________
Jul 20, 2007 02:37 | #9 Thanks IainB, I'll try that.
ayotnoms Perfect Anti-Cloning Argument 2,988 posts Joined Jan 2005 Location: San Francisco Bay Area More info | Jul 20, 2007 06:34 | #10 Damo77 wrote in post #3577968 ...Basically, Curves does the same thing, but without the histogram to tell you if you're destroying detail. Just to be precise, curves in CS3 does include a histogram and even has a box you can check to notify when clipping is occuring. Steve
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Jul 20, 2007 06:49 | #11 Curves is more flexible, because you can set (up to eight IIRC) different points on the curve, which can be dragged: You determine what 'light level' you are changing. "I think the idea of art kills creativity" - Douglas Adams
rdsmith3 Senior Member 690 posts Likes: 10 Joined Feb 2006 Location: Flanders, NJ More info | Jul 20, 2007 08:16 | #12 Damo77 wrote in post #3577968 Until you really know the answer to your own question, I'd recommend principally using Levels. Adjust the end (shadow and highlight) sliders first, taking care not to "clip" data - ie blow out highlights and fill in shadows. The histogram tells you if you are doing so. Then adjust the middle (midtone) slider for satisfactory lightness. Basically, Curves does the same thing, but without the histogram to tell you if you're destroying detail. With levels, hold down the Alt key while you are moving the left and right sliders to see if your are blowing out highlights or losing shadow detail. It will show you where this is happening. Bob Gear List
vetkrazy Goldmember 1,019 posts Joined May 2006 Location: Just North of South, next to the Joshua tree More info | Jul 20, 2007 10:17 | #13 Yea, thats one of them. I am on the east side, near the new high school. TeriD wrote in post #3578469 Hey Bruce, Didn't know anyone here was from this area. Good to see a neighbor. Is that your vet in your avatar? It looks familuar. Are you located on the east or west side? I could defintly use some pointers, this photography is harder than it looks so I just might take you up on it. Wrap your ass in fiberglass.... You're only young once but you can be immature the rest of your life
mprice Member 49 posts Joined Mar 2007 Location: Land of Lincoln More info | Jul 20, 2007 11:33 | #14 Look at this site for some easy to understand curves and levels information.
Jul 20, 2007 13:03 | #15 Thanks everyone and thanks for the link mprice.
| Latest registered member was a spammer, and banned as such! 2867 guests, 140 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
