Thread started 20 Jul 2007 (Friday) 06:19
better to transfer over usb or CF reader? (wrt longevity)
jkoc
Jul 20, 2007 06:19 |  #1
so i've been shooting stuff outside of the house and then transfering the image to my laptop back and forth so i can view it on a larger screen. i ended up doing this several times but that got me thinking, is it better for body longevity to transfer via the USB cable attached to the body or take the CF in/out constantly?
it seems like over time, either CF slot DOOR latch could "wear out" and become loose. on the other hand, if i keep using USB cable, the connector could come less 'snug' over time ahaha.
for those of u who have owned the same dslr for a few years now, what do you guys do usually? am i just paranoid and should shut up and just keep shooting?
scot079
Jul 20, 2007 06:22 |  #2
if you're just shooting jpeg, then it's ok hook the cam up USB. If you've got RAW on the card, then it's better to take the CF out of the camera and use a reader.
- Tim
www.timadkinsphoto.com (external link)
GEARandFEEDBACK
pwm2
"Sorry for being a noob"
Jul 20, 2007 06:36 |  #3
If the USB connector on the camera wears out, you can continue to use the camera.
I wouldn't worry about the door latch, but if the CF connector wears out, you must repair the camera.
However, the connectors don't wear out too quickly. If you fill full cards, it's a lot faster to pick out the card and use a CF reader. For single images now and then, I would recommend the USB cable. Professionals who shoot full days don't have much option. They just have to switch cards, since they can't take the time to copy out all images, clear the card and then continue shooting.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Jul 20, 2007 06:41 |  #4
pwm2 wrote in post #3579124 (external link)
100% spot on, I agree!
jkoc
Jul 20, 2007 07:03 |  #5
pwm2 - hey good point about "If the USB connector on the camera wears out, you can continue to use the camera."
i think for quick shoot & verify moments, i'll use usb . and for big 4gb cf dumps, i'll use card reader since its also faster.
peber
Jul 24, 2007 03:28 as a reply to  @ jkoc's post |  #6
Another question then... This little rubber thing that covers all the connectors... To me it seems a bit risky to open and close it too often, feels like the rubber will wear out and it will fall off. Has that happened to anyone?
/Per
IT Consultant by trade, photographer by heart
pwm2
Jul 24, 2007 03:47 |  #7
Not on a Canon yet, but quite soon on other cameras.
kpt4321
Jul 24, 2007 08:09 |  #8
scot079 wrote in post #3579084 (external link)
Why would the picture format matter?
dilorenzo1954
Gallery: 210 photos
Jul 24, 2007 08:16 |  #9
kpt4321 wrote in post #3601649 (external link)
A card reader is usually faster for downloading RAW images
Ed
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jul 24, 2007 09:53 |  #10
Card reader is soooo much more convenient.
CDS' HOT LINKS
stevieboy378
Jul 24, 2007 09:58 |  #11
I prefer to use the USB cable, if only because I'm paranoid about bending one of those delicate little CF connector pins as I change cards . . .
EOS 5D & 350D
EF 24-105L IS | EF 70-200f4L | EF 17-40 f4 L | EF 50 f1.4 USM
430EX Speedlite
Epson P-2000 | Photoshop CS3 | Lightroom 2
gjl711
Jul 24, 2007 10:04 |  #12
Looking over a few sites, the SD cards have about a 1,000,000 hours MTBF and a 10,000 insert/removal life cycle. So, if you took the card in and out 5 times a day, you have about 5.5 years before the card wears out.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
gjl711
Jul 24, 2007 10:05 |  #13
stevieboy378 wrote in post #3602188 (external link)
Arn't the pins on the micro USB plug pretty small as well?
::Gear::
stevieboy378
Jul 24, 2007 10:19 |  #14
gjl711 wrote in post #3602222 (external link)
Yea, but bending one of those won't render the camera unuseable . . .
EOS 5D & 350D
430EX Speedlite
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Jul 24, 2007 11:01 |  #15
No, USB connectors don't use pins -- they have sliding spring contacts.
CF cards and SD cards don't have an MTBF -- the correct terminology is MTTF since it is a non-repairable assembly. The life cycle times that quoted above for read/write operations and insertion/removal cycles are applicable to SD cards only. SD cards utilize sliding contacts which can't be correlated to the large number of fragile pins on a mating connector for a CF card.
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill (external link)
Donate to Support POTN Operating Costs
2,532 views & 0 likes for this thread, 19 members have posted to it.
2876 guests, 134 members online
