Thread started 20 Jul 2007 (Friday) 16:32
Saving RAW images
shane_c
Jul 20, 2007 16:32 |  #1
I went and took a few RAW images of the dog last night and the quality was night and day from the jpegs I usually shoot and this was only with changing the white balance. So once I open the RAW images in CS3 and make my adjustments what is the best way and format to save the adjusted image?
Canon R5 - Canon RF24-105L F4, Canon 40mm, Canon 70-200L F4 (non-IS), Canon 100-400ii, 1.4xiii
G1X MK2, G15
My Instagram (external link)
etaf
Jul 20, 2007 16:44 |  #2
it depends on what you intend to do with the image
I often save in photoshop format if i have doen a lot of manipulation and layers etc.
also save as a TIFF
depends on how important the image is and how complicated the adjustment was
60D | EF-S 18-200 | 50mm 2.5 macro | 550EX | Pro1 | Elements
davidcrebelxt
Jul 20, 2007 17:29 |  #3
For final output, you are usually fine saving as .jpg. (use highest quality). Saves on disk space, and makes it easier to share your images with anyone.
After your initial conversion, you may consider making that your "master" copy (keeping the RAW as your "negative" too), and then only working on a second copy, that way you have an original to go back to.
If I have alot of edits, I'll save as .psd (photoshop format) so that I preserve my layers, and I could go back in and adjust them.
It really all depends on how concerened you are with preserving edits, and what steps you want to add to your workflow. (and everything etaf said too.)
David C.
Equipment: Canon Dig. Rebel XT; 18-55mm EF-S; 28-105mm EF; 50mm 1.8 EF
Sigma ef-500 DG ST, Elements, Gimp, Lightroom
http://www.flickr.com/​photos/dcrebelxt (external link)
lowcrust
Jul 20, 2007 22:03 |  #4
I save the raw on the computer (in my lightroom library) and export to reasonable sized jpg (usually 80 to 90% quality) for web, small prints or slideshow viewings (e.g. on my projector).
If I've done PP in PS I save the PSD on the computer and when the folder reaches 4GB I burn it down to DVD and erase the files from the HD. That way I can easily bring back the file if I suddenly realize that I wanna try another edit. If the DVD should fail at some point I still have the jpg to look at and the raw/dng to work with.
Raw plus jpg are backed up on an external drive as well as burnt down on DVD.
~ BORN FREE - TAXED TO DEATH! ~
1,657 views & 0 likes for this thread, 4 members have posted to it.
Saving RAW images
2867 guests, 140 members online
