Thread started 21 Jul 2007 (Saturday) 13:44
Matte cutting and blade sharpness
3Honu
Jul 21, 2007 13:44 |  #1
Dude!!!
I am only getting one frame from each blad I use. I am using the Logan 301 with the blades it came with. Is this normal?
2 Samuel 9:7-8, "So David said to him, “Do not fear, for I will surely show you kindness for Jonathan your father’s sake, and will restore to you all the land of Saul your grandfather; and you shall eat bread at my table continually.” Then he bowed himself, and said, “What is your servant, that you should look upon such a dead dog as I?”
howzitboy
Jul 21, 2007 13:55 |  #2
thats odd, the blades should last pretty long unless the mattes you are cutting are really thick or dense board.
http://onehourwedding.​blogspot.com/ (external link)
3Honu
Jul 21, 2007 18:09 |  #3
If the backer board was worn would that do it?
R ­ Hardman
Jul 22, 2007 09:59 |  #4
What size are the frames. I toss blades right after I cut one frames worth also . I'd rather have a easy clean cut since the cost of the blades are cheaper then re-cutting mats. Dull blades tend to have tear-out. Your backerboard should be replaced frequently also. It will cause the cut to drift and produce ragged cuts.
"Whatever you can do to avoid Photoshop is worth it"
EOS 7D, EOS 350D, EF 17-40mm f/4L USM, EF 70-200mm f/4L USM, EF-S 18-55mm f/3.5-5.6 USM (Kit)
Rick's Digital Desert (external link)
869 views & 0 likes for this thread, 3 members have posted to it.
2844 guests, 135 members online
