Thread started 23 Jul 2007 (Monday) 09:42
Post Processing help needed
jlg759
Joined Jun 2005
Jul 23, 2007 09:42 |  #1
I need a little post processng help to make this shot look better. I would like to remove the distracting parts of the wall starting in the upper left corner and going horizonal accross the tp of the photo. I did this in photoshop however when I try to print the image I get a white band accross the top and bottom of the photo even at 4x6 ( photo won't fit page). So I have 3 questions Please help. The full sized image was not allowed here the original was shot with a rebel xt full size JPEG.
1. Can this photo be fixed if so would you mind sharing your steps so I can learn?
2. Should I not zoom in so close when I take the photo's and resize during post processing to reove items? I shoot a lot of drag racing stuff and run into this problem during post processing
3. I forgot the last question LOL
Joe
Roy ­ Mathers
I am Spartacus!
Jul 23, 2007 10:10 |  #2
How about this? This is a 6x4 crop with the top of the wall cloned out. Is this what you mean? This was a very quick operation and, with more care, you could do a better job;)
jlg759
Joined Jun 2005
Jul 23, 2007 10:14 |  #3
Thank you Roy Did you use photoshop and just cut the top off ? This is what I need to know. Thanks Joe
ThePolster
Jul 23, 2007 10:19 |  #4
No, he cloned the wall. Notice how the wall is wider in his picture (actually, taller..lol).
Roy ­ Mathers
I am Spartacus!
Jul 23, 2007 10:22 |  #5
The Polster is right. First I cropped it to a 6x4 format. This left a little of the sky showing along the top right of the picture, and this was cloned out. Done on Photoshop in about 5 minutes (or less).
jlg759
Joined Jun 2005
Jul 23, 2007 10:35 |  #6
still kinda new to post processing what do you mean by cloned ? What tools / program do you use for that Sorry to be a pest but still learning
Roy ­ Mathers
I am Spartacus!
Jul 23, 2007 11:28 |  #7
The program I use is Photoshop but the cloning facility is available on most imaging software. Cloning is really copying a little piece of the image and placing it somewhere else on the image. For instance, in your picture, I copied little bits of the wall and 'stuck' them on the sky, to make it look like a taller wall. I've probably not explained this at all well but I would suggest that a search, either in this forum, or on Google, will bring you lots of information as to how to apply the technique.
chauncey
Jul 23, 2007 14:19 as a reply to  @ Roy Mathers's post |  #8
You must be very careful in using these techniques. Before you realize what is happening, you can become addicted and buying things like Photoshop CS3. It can almost take over your life.
You see, I speak from experience and must go to the weekly meetings to keep it under control.
howzitboy
Jul 23, 2007 23:32 |  #9
HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by TINYPIC
i just cloned everything i could to get that wall bigger.
http://onehourwedding.​blogspot.com/ (external link)
inthegarden
Joined Jun 2003
Jul 24, 2007 01:54 |  #10
Joe[/QUOTE]
Since no one really answered this question - Yes, leave yourself some room to resize, especially if you need the finished size to be a set dimension, like 4x6. If you do own photoshop, I highly recommend that you take a class in your area, or get yourself a good book to guide you in the basics (amazon.com is a great place to search). There are also tons of sites online with tips and tutorials.
"A poorly made picture that moves us is worth hundreds of empty masterpieces of technique. And when good photos are made well, that's even better." David Vestal
1,265 views & 0 likes for this thread, 6 members have posted to it.
2876 guests, 134 members online
